Tuning Standing Rigging after Mast Stepped - Page 3 - SailNet Community
 7Likes
post #21 of 31 Old 06-20-2014
Dave_E's Avatar
Re: Tuning Standing Rigging after Mast Stepped
To my mind. the big benefit of a Loos is that you get the same tension on all the shrouds & stays.
Doing it by feel works, and has worked forever but it isn't good at getting them all the same - or repeatability for that matter. A given tension feels tighter on a shorter wire like a lower than it does on an upper or backstay.
Bump. No sailor who does the work himself (or at least general upkeep) should be without this tool.
Allmand Sail 31 #15 "Traveler"
GOD, Family, career
Dave_E is offline
post #22 of 31 Old 06-20-2014
christian.hess's Avatar
jajaja it was an error on my behalf...I apologize...
I wasnt bagging on using the gauge btw
carry on
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #23 of 31 Old 06-20-2014
Minnesail's Avatar
Figures, one more damn thing I should buy.
Catalina 22
on a starboard tack
Minnesail is offline
post #24 of 31 Old 06-20-2014
Senior Citizen
Chas H's Avatar
Now for best price on a Loos.
Rigging sizes determines which gauge to buy.
Defender prices:
Defender.com Search Results: loos
Please post if you find for less $.
-CH
Chas H is offline
post #25 of 31 Old 06-21-2014
Senior Moment Member
SloopJonB's Avatar
Defender prices:
-CH
One word - Craigslist. I got an almost unused one for $40 and I've seen others around the same price.
SloopJonB is offline
post #26 of 31 Old 06-21-2014
SloopJonB's Avatar
Originally Posted by MedSailor View Post
It's okay, you can say it. I'm too dumb to do it by feel.
MedSailor
Naahh - you're plenty smart enough, you just need more feeling.
MedSailor likes this.
post #27 of 31 Old 06-21-2014
SloopJonB's Avatar
By the way Med - can I assume from your avatar that you sold your Leaky Teaky and bought a Nauticat?
post #28 of 31 Old 06-21-2014
MedSailor's New Ride! (maybe I am a power-boater after all...)
Faster is offline
The Following User Says Thank You to Faster For This Useful Post:
SloopJonB (06-21-2014)
post #29 of 31 Old 06-21-2014
Admitting that the gauge is a good idea, I've done it by hand and eye now for 25 years.
As described by others, halyard brought to chainplates to get it pointed straight up port/starboard, using the uppers, then working my way down on the rest of the shrouds while sighting up the mast to make sure it stays straight and true. Forestay is usually left untouched with the roller furler, backstay is dynamically adjusted anyway based on wind conditions. If you've got mast wedges, put them in after the static tune.
After doing all that, take it sailing, load up the rig on both tacks, and sight up the mast and make sure it's straight under load. Retune if necessary. Then in go the pins.
I've heard different opinions on how loose the leeward shrouds should be when not under load on a tack. Personally, I don't like them to be rattling around. I set them tight enough not to sag.
One good idea when you get it set, mark the turnbuckles with tape before stepping so next year's setup is easy. A good yard will usually do this to save themselves the trouble.
capecodda is offline
post #30 of 31 Old 06-21-2014
I'm surprised that no one has mentioned the folding rule method. Selden has info on this method and I use it to tune my rig.
lancelot9898 is offline
Irwin Citation 34 Mast/Standing Rigging/Sails Alli-Cat27 Gear & Maintenance 3 09-16-2013 07:35 PM
Deck-stepped vs. keel-stepped mast psemme Seamanship & Navigation 7 11-16-2010 09:23 AM
What is a Deck-stepped mast and keel-stepped mast djr3203 General Discussion (sailing related) 11 12-25-2009 08:24 PM
Mast Standing Rigging Spreader Replacement. sce56 Gear & Maintenance 2 05-08-2009 11:12 PM
Standing Rigging Tuning fireman181 Gear & Maintenance 4 12-20-2007 01:01 PM
