Stainless Fabricator Recommendations for Bent Anchor Roller? - Page 2 - SailNet Community
 6Likes
post #11 of 16 Old 06-24-2014
christian.hess's Avatar
Re: Stainless Fabricator Recommendations for Bent Anchor Roller?
all fine and dandy...however it will be weakened just remember that...stainless is brittle.
ill leave it at that
it will work fine but the pos roller already bent it somehow
next time it will bend twice or 3 times as easily and possibly be beyond repair
this is one of those cases(like bending back a handlebar on a motorcyle) where you know youre on borrowed time...
and most importantly DO NOT USE HEAT
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #12 of 16 Old 06-24-2014
overbored's Avatar
That one should be easy to bend back. I have done several. they do bend easily, 300 series stainless is actually a soft steel, it can not be heat treated, it does work harden when bent and if worked enough it will become brittle and break but you would have to bend it back a forth a hundred times before it would break. I have straightened a couple of these brackets by cutting a two by four down to fit inside the plates, clamp with a big C clamp and twisting them straight on the boat. your looks like a candidate to try this on.
christian.hess likes this.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #13 of 16 Old 06-25-2014
Wingnut
Scrap it and start over with something that is strong enough in the first place. I made mine out of half inch plate. Stainless of course. Also, use a bolt to put the roller through so you can take it out easily.
Sent from my HUAWEI Y300-0151 using Tapatalk
Dirtyfloats is offline
post #14 of 16 Old 06-25-2014 Thread Starter
4arch's Avatar
Sounds like a great idea but any idea where I can have something like that fabricated at reasonable cost?
s/v Spindrift
Beneteau Oceanis 400
formerly Lippincott 30
4arch is offline
post #15 of 16 Old 06-25-2014
any machine shops around? doesnt have to be a marine place...
most good places can work with basic diagram or drawing with measurements
thats how I do it down here
post #16 of 16 Old 06-25-2014
Wingnut
Anyone with welding skills and a drill press can build it. Taking it to a machine shop is likely to be more expensive than it needs to be. If you are able to do the prep work before taking it to a welder, you will save a bunch of money. Same is true if you can do that after welding cleanup.
Chainplate Fabricator Recommendations? jasn Gear & Maintenance 10 03-10-2014 08:03 PM
Stainless Steel Mantus Anchor Mantus Anchors Gear & Maintenance 0 12-26-2012 11:16 AM
straightening bent anchor roller extremo Gear & Maintenance 13 04-14-2012 08:36 PM
Anchor roller nikonf3blue CS Yachts 1 04-02-2010 07:45 AM
need the name of a good stainless steel fabricator jimmcmahon Gear & Maintenance 4 11-18-2005 09:07 AM
