Replacing wire halyards with line on Columbia 26 MKII - SailNet Community
 1Likes
post #1 of 24 Old 06-30-2014 Thread Starter
I'm thinking about changing both my main and jib halyard to line from the original wire/line mix. I'm thinking about replacing them with 5/16" line. Does anyone know if the sheaves at the mast head will take 5/16" line?
Thanks.
1971 Columbia 26 MKII
bll30148 is offline
post #2 of 24 Old 06-30-2014
Minnesail's Avatar
Re: Replacing wire halyards with line on Columbia 26 MKII
I am contemplating the same switch on my Catalina 22. In my case the sheaves need to be changed to accommodate 5/16" line.
Catalina 22
on a starboard tack
Minnesail is offline
post #3 of 24 Old 06-30-2014
christian.hess's Avatar
you do not need to change sheaves out...unless you really want to
new line is quite a bit stronger and less stretchy for the same diamater, SOOOOOOOOO
if you want to save some $$ especially on smaller boats, switch out the wire rope halyards to a 1 size down all line halyard...
cheers
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #4 of 24 Old 06-30-2014
69' Coronado 25
socal c25's Avatar
Dock
I am going to do the same on my Coronado 25 BUT I am going with 3/8 as its easier on the hands AND I have the lines ready to come back to the cockpit, cabin top winch and rope clutches. I do have to change the sheaves cause I don't want my lines ruined by the grooves, I am also going internal and coming out the bottom of the mast. The red line in the pics is a fake just to line things up.
"There are those that stand at the shore looking to the sea, wondering, and there are those standing at the helm looking back at shore, knowing." - Kurt Leisenfelder
"Fiberglass shells that let us breathe, let us smell, keep us from going numb"- Kurt Leisenfelder
My Avatar is a pic of my son - Jan 19, 2014.
socal c25 is offline
post #5 of 24 Old 07-02-2014
I considered the same change, but then realized that when the sails are raised, the entire run under stress is all wire except for the final 18 inches at the mast cleat... and 18 inches of line, no matter how old, can't stretch nearly as much as a full-run of new all-rope halyards will. Yes, my lines are old and a bit dirty, but the wire portions are still fine and in the final analysis I could come up with better ways of spending boat money.
If you race, wire has less wind-resistance too.
I'm not trying to challenge your thinking... but just share a conclusion I reached from the same circumstances.
hriehl1 is offline
post #6 of 24 Old 07-02-2014
RichH's Avatar
Use non-stretch modern polymer line such as 'dyneema', or 'am-steel' etc. Typical daron polyester is simply too 'stretchy' to be used for halyards, especially if you heavily load-up your halyards to affect good sail shape and to hold that shape during 'heavy' wind conditions to prevent the sail(s) from 'power-ups'.
The only problem in replacing with polymer is if your current wire-rope halyard has a 'ball' swaged to the wire and the 'ball' fits into into a special 'ball cleat' to hold the wire tension (instead of a horned cleat).
RichH is offline
post #7 of 24 Old 07-03-2014
Senior Moment Member
SloopJonB's Avatar
I despise wire running rigging. Unless your halyard is all wire, the sheaves are configured to handle both wire and line. Changing to all line the same size as your existing tails is a matter of joining the tail of the old to the head of the new and hauling them up & over. I've done it many times.
SloopJonB is offline
post #8 of 24 Old 07-03-2014
Minnesail's Avatar
What are the minuses to wire running rigging? What do you gain by changing it out?
Catalina 22
on a starboard tack
post #9 of 24 Old 07-03-2014
you dont gain anything...only reason to replace is if they are fraying.
if you do replace I would recomend going 1 size down...no need to go same size since line today is much stronger per same size
thats just me though
post #10 of 24 Old 07-03-2014
JimsCAL's Avatar
Just replaced the wire/line main halyard on my Cal 33 with all line. Went with New England VPC which is a "mid tech" line. The cover on the old halyard was in bad shape in several spots, so it was time. Never considered staying with wire/line.
JimsCAL is offline
rope & wire halyards vs all rope halyards kjango Gear & Maintenance 20 03-02-2013 02:16 PM
Wire to Rope Halyards casey1999 Gear & Maintenance 16 05-23-2012 02:52 AM
Looking at a Columbia 29 MKII souljour2000 General Discussion (sailing related) 12 10-18-2011 09:00 PM
Wire halyards doctom Gear & Maintenance 5 06-14-2007 08:49 PM
Replacing wire halyards with rope DRM Gear & Maintenance 2 03-21-2006 03:49 PM
