solar recommendations - Page 2 - SailNet Community
 14Likes
post #11 of 44 Old 07-02-2014
mitiempo's Avatar
Re: solar recommendations
Originally Posted by andyselzn View Post
Sunforce seems to have 80, 100, and 150W for 12volt systems. No other options at this site. Sunforce 100 Watt Crystalline Solar Panel
That is a bit pricy. I sell a 100 watt flexible panel with the same output for $399 Cdn. 85 watt aluminum framed for $299 Cdn.
Here is a better source: 1 to 100 Watt Solar Electric Panels at Arizona Wind and Sun.
andyselzn likes this.
Brian
mitiempo is offline
The Following User Says Thank You to mitiempo For This Useful Post:
andyselzn (07-04-2014)
post #12 of 44 Old 07-02-2014
aeventyr60's Avatar
I've had Kyocera panels on my boat for 15 years. Still putting out full power. Tough frame for mounting. Good cable grommets that don't leak. Maybe a bit more expensive,but worth it for the long term.
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is online now
post #13 of 44 Old 07-02-2014
Broad Reachin'
kwaltersmi's Avatar
I've got a rollable 14W panel from PowerFilm that's durable and well-made. I believe they make rollable panels up to 60W.
Catalina 34
kwaltersmi is online now
post #14 of 44 Old 07-02-2014
It is not so much the size of your batteries... it is your pattern of using the boat. How many amp-hours are you consuming between charges?
First, I am assuming you stow the panels while underway in a smaller boat... they'd be in the way underfoot.
If you're on a 5-day cruise, sailing hard every day with instruments, VHF, TP22, etc., then spending the evenings at anchor listening to tunes and using lights... then you'll have lots of amp-hours to recoup once you do place the panels in sunlight service.
If your use is more of weekend use, maybe two daysails surrounding one overnight evening at anchor, you have much less to recoup.
Last, when you do charge via panel, how long before you're using the boat again? If the boat will be idle and charging for days, a smaller panel should suffice. If you'll be right back out in a day, a larger panel is called for.
For what it is worth, on my 28-footer with similar equipment to yours, my weekend-use pattern is easily-supported by one Group 27 90AH deep cycle battery recharged during the work week with a 30 watt panel ($65 on eBay). My battery very rarely gets below 12.55 volts... and after a charge typically reads in the low 12.7s.
hriehl1 is offline
post #15 of 44 Old 07-02-2014 Thread Starter
The plan is to cross from SF to Hawaii some day. That is about 20 days of solar only power for the devices mentioned. So planning accordingly.
andyselzn is offline
post #16 of 44 Old 07-02-2014
no longer reading SailNet
Alex W's Avatar
They aren't make small panels suitable for small boats anymore. Their smallest panel is 140W and 60" by 26". I don't know where you would fit that on a Bristol 24 without shading.
I am using a cheap Chinese panel on my boat. I'd have preferred to buy something higher quality (or at least from a brand that I've heard of), but quality rigid small panels seems to be a very limited market these days.
Alex W is offline
post #17 of 44 Old 07-02-2014
I have been using solarblvd.com for several projects and have been happy
Look into 2 6v 115/120Ah batteries (golf cart) for your 12v needs also, I would rather have the reserve power there(that will give you 120Ah total @ 12v)
size will be an issue on a boat, unless you can tilt them to the sun you may only get 3 or 4 hrs of decent sun per day( if that much with shadows and sails etc)
So your 100wt panel may only be putting out 8 or 9amps per day, thats not much
you may need to look at several 40/50/60 watt panels for their size and just tie them all together at the controller or daisy chain them
bansil is offline
post #18 of 44 Old 07-02-2014
Good solar panels: Most are well-behaved but obedience training usually isn't expensive if they need it.(G)
Two ways to go, the expensive brand name with a specific "marine use" warranty. Or, generic Chinese product with the expectation that it will not hold up as well but is cheap enough to replace when it fails, assuming that isn't a critical time. Like halfway to Hawaii.
Congress just raised a 30%(?) tariff on the panels the Chinese have been dumping on the US market, so expect prices to go way up real soon.
hellosailor is offline
post #19 of 44 Old 07-02-2014
mitiempo's Avatar
Golf cart batteries are 220 - 240 AH so 2 will give you 220 - 240 AH @ 12 volts.
A 100 watt panel is rated at about 5.6 amps. With a good controller (MPPT) that can get an output of about 7 amps at charging voltage. On a sunny day without panel shading you can get about 35 AH into the batteries from such a panel.
If you are only getting 8 or 9 AH per day something is wrong.
Brian
mitiempo is offline
post #20 of 44 Old 07-02-2014
mitiempo's Avatar
As far as I know Kyocera is the only panel that has a "marine" warranty. Siemans may have had one but they are gone.
Brian
mitiempo is offline
SOLAR JACK solar panels? christian.hess Electrical Systems 14 08-24-2016 10:55 AM
Solar deck instead of solar panels ulferlingsson Gear & Maintenance 34 01-31-2013 05:03 AM
Anyone bought solar panels from Sun Solar? justonemoreproject Electrical Systems 1 04-18-2012 05:08 PM
solar recommendations please newhaul Gear & Maintenance 43 03-07-2011 08:19 AM
Recommendations, please. WinterRiver Boat Review and Purchase Forum 9 12-05-2006 08:06 PM
