-   -   solar recommendations (http://www.sailnet.com/forums/gear-maintenance/150714-solar-recommendations.html)
andyselzn 07-02-2014 01:47 AM
Looking for good solar panels. Recommendations? :)
It is for a Bristol 24. It has space on the hatch, transom outboard well, and forward hatch.
Energy Plan
- Two Batteries: 120 amp hrs (total for both batteries)
1. Tiller Pilot (TP22)
2. Depth Sounder
3. Knot Meter
4. iPad
5. Garmin Glo (Blue tooth GPS feed to ipad)
6. Radio w/AIS (Standard Horizon GX 2150)
7. Navigation lights
8. Interior LED's
I currently have one portable, foldable 25 watt panel.
Alex W 07-02-2014 02:07 AM
Re: solar recommendations
What region do you sail in, what times of year do you sail, and how often do you want to plug into shore power?
A 50w panel with a good controller (like the Genasun MPPT) would probably be more than enough.
andyselzn 07-02-2014 02:40 AM
SF Bay Area. Want it to be offshore capable. Say SF to Hawaii. Will look up Genasun MPPT. Any recommendations on the 50W panel brand and vendor?
mitiempo 07-02-2014 02:56 AM
I agree on the Genasun - you won't find a better small panel controller.
Which batteries are you using that only have 60 AH each?
andyselzn 07-02-2014 03:10 AM
Haven't bought the batteries yet. Thought I would throw in some specifications or it would be pretty vague question. Am leaning towards two 27 batteries which are 90A each. I am guessing that they will take on and release charge when going from 80 to 50% and then charged back up to 80.
Still interested in a manufacturer/vendor for the panels. :)
mitiempo 07-02-2014 03:13 AM
With solar they will charge past 80%. 100% if enough sun with little DC use.
Lots of good brands of panels. I would avoid E Bay and buy from a reputable solar retailer in your area.
andyselzn 07-02-2014 03:18 AM
I have heard that some retailers can be as little as $1/watt. Also, wondering about the other specs: weight/height etc. Are the ones for marine use different?
mitiempo 07-02-2014 03:30 AM
There is no specific marine solar panel really. They are all designed and built to withstand the elements.
Buying at $1 a watt leads you to the bottom of the barrel in quality in most cases. $2 to $3 a watt is more normal I think, maybe $4 a watt for flexible panels like those from Go Power.
The other issue is panel size. The price per watt drops as the panel gets larger but you probably want a small panel - somewhere under 100 watts.
andyselzn 07-02-2014 03:39 AM
Sweet. Please point me to one or two online vendors. Oregon preferred.
andyselzn 07-02-2014 03:47 AM
Sunforce seems to have 80, 100, and 150W for 12volt systems. No other options at this site. Sunforce 100 Watt Crystalline Solar Panel
