older prpopane tank adapters - SailNet Community
post #1 of 3 Old 07-02-2014 Thread Starter
I have an older sailboat with 10lb upright aluminum propane tanks. According to a re-filling service I can't re-fill the tanks because the fill fittings are out of date. Are there any suppliers that could re-fit the tanks?
jefffuji35 is offline
post #2 of 3 Old 07-02-2014
Sailor
Gladrags1's Avatar
Re: older prpopane tank adapters
Yes. Your tank must also be decertified that it can hold the pressure. Check with local propane supplier for companies in your area.
Sent from my iPhone using Tapatalk
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #3 of 3 Old 07-02-2014
rbrasi's Avatar
Trust me when i tell you this- ditch the old tank and buy a new one. I don't know which state you are in, but here in California, if you don't have an OPD valve they won't fill it and some of the old tanks don't have the right size opening to put one on. The time you spend (waste) looking for someone to do this can be saved if you just buy a new tank and be done with it. In my case, I have to build a new propane locker because the size of my tanks is no longer produced. Anywhere.
1968 Cal 2-30
Sandpiper 2
MDR
rbrasi is offline
Scotty, I Need (adapters needed on board) More Power, So Hook Me Up ! HighFly_27 Electrical Systems 1 11-11-2012 10:45 PM
hang on to your shore power adapters! nodders Gear & Maintenance 5 05-10-2012 05:25 PM
Convert existing steel freshwater tank to blackwater holding tank? patrickstickler General Discussion (sailing related) 7 09-24-2010 07:55 PM
Where to find Bango pumpout adapters? samoss Gear & Maintenance 4 06-27-2006 11:12 AM
Fuel fill (pipe) to (hose) adapters pjfsail Gear & Maintenance 2 09-26-2004 09:30 AM
