furler - SailNet Community
 22Likes
post #1 of 48 Old 07-03-2014 Thread Starter
furler
What is a good low cost furler for a 24 foot boat (6000 lb displacement)?
andyselzn is offline
post #2 of 48 Old 07-04-2014
no longer reading SailNet
Alex W's Avatar
Re: furler
Hanks.
Furler upgrades aren't low cost. You'll need a new jib and probably a new forestay as well. The furler is less than half the cost of the system.
A jib bag is a cheap upgrade to a 24' boat that makes handling the jib easier (you can flake it on the foredeck) without the costs of furlers.
andyselzn likes this.
Alex W is offline
The Following User Says Thank You to Alex W For This Useful Post:
Multihullgirl (07-04-2014)
post #3 of 48 Old 07-04-2014
first sailed january 2008
northoceanbeach's Avatar
Re: furler
Harken makes a lower cost option...ESP is it? And then mark iv is the more racey, foil one. You could investigate harken options.
northoceanbeach is offline
post #4 of 48 Old 07-04-2014
Doesn't sail enough
zedboy's Avatar
Re: furler
There is some stuff online for building your own furler, basically you find some good swivel hardware and then build yourself a drum to fit on it. Could be doable for a 24' boat, not sure I'd want to try it much bigger than that.
Doing a jib bag (sailrite kit, or roll-your-own) could be nearly as good a solution if your real goal is getting on the water quick.
zedboy is offline
post #5 of 48 Old 07-04-2014 Thread Starter
Re: furler
mainly concerned about bringing jib down while single handing in heavy weather. am working on putting jack lines together.
will look at Harken and jib bag options.
are the DIY ones pretty robust if done right? is there something about the manufactured ones that cannot be replicated?
post #6 of 48 Old 07-04-2014
Doesn't sail enough
zedboy's Avatar
Re: furler
It's all about the quality of your swivel - that's what's carrying the forestay tension.
A furler is not a perfect heavy-weather solution; can't easily furl the jib when it's under pressure.
zedboy is offline
post #7 of 48 Old 07-04-2014 Thread Starter
Re: furler
@zedboy, if you were singlehanding in heavy weather, would you go with the jib bag or the furler?
what the cost of the parts add up to, approximately, for a DIY?
The Following User Says Thank You to andyselzn For This Useful Post:
windmagic (07-08-2014)
post #8 of 48 Old 07-04-2014
Doesn't sail enough
zedboy's Avatar
Re: furler
I can't answer that - I've had the luxury of knowing when it's going to be nasty, and putting on the 85% blade at the dock. My old boat was about the size of yours. When it got really nasty out, I stayed put :-) though it did sail alright under storm jib and mizzen. No chance of making much way to weather like that.
zedboy is offline
post #9 of 48 Old 07-04-2014
Sailor
Gladrags1's Avatar
Re: furler
When single handing your success at sail handling is going to rely more on early weather prediction and early sail handling than anything else. Reduce sail before it is a necessity. Rolling up a furler in heavy conditions is extremely difficult. Sometimes it tempts you to use a winch on the control lines which puts high loads on the rigging. Where are your halyards tied off? At the mast? It would be easy to place the bag, free the halyard and quickly pull down the jib. If necessary, quickly lash sail on deck to secure until conditions improve and you can stow the sail. My vote is on the bag.
Tod
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
The Following User Says Thank You to Gladrags1 For This Useful Post:
post #10 of 48 Old 07-04-2014
tommays's Avatar
Re: furler
My gear has proven it self to furl correctly in anything we care to sail in while allowing a balanced easy to handle boat
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
Furler? scotthardwick Gear & Maintenance 4 05-09-2014 03:39 PM
What's this on the furler? Dave_E Gear & Maintenance 5 11-26-2013 09:50 AM
Which Furler? sdinger General Discussion (sailing related) 7 03-09-2012 07:50 PM
rolling furler QuickMick Gear & Maintenance 2 04-01-2010 10:37 AM
A Furler? jetdrvr393 Gear & Maintenance 6 11-10-2009 08:56 PM
