adhesive for foam (DIY cushions) - Page 2 - SailNet Community
 6Likes
post #11 of 14 Old 07-07-2014
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Re: adhesive for foam (DIY cushions)
The only way I would try to make a piece of foam longer (like uncutting a sandwich) would be with several smaller layers of foam sandwiched together but staggered. This would keep some of the stress off of the vertical seams as they would be spread out and held together with the horizontal seams
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #12 of 14 Old 07-07-2014
Bill SV Rangatira
Bill-Rangatira's Avatar
Send a message via Skype™ to Bill-Rangatira
Originally Posted by andyselzn View Post
Looking for a good adhesive for sticking together pieces of foam.
A sheet of foam was cut up for the cushions. And, a couple of pieces need to be put together to make a whole. Is there something like a 4200 but for foam to foam?
you need what we used to call in the construction industry a board stretcher
Bill-Rangatira is offline
post #13 of 14 Old 07-08-2014 Thread Starter
what is a board stretcher?
andyselzn is offline
post #14 of 14 Old 07-08-2014
finding41's Avatar
Send a message via Skype™ to finding41
I've had god luck with the Elmers spray glue. But that was horizontal.
I would glue a piece of fabric to the top and bottom of your end to end glue experiment. Like the ham sandwich. The fabric will keep the foam together. In theory any way.
It may stiffen the feel of the cushion too.
finding41
Marty Jackson
finding41 is offline
Foam for interior cushions?? Adele-H General Discussion (sailing related) 33 01-06-2013 08:09 AM
Boat cushions from stock foam xluke Gear & Maintenance 10 04-24-2011 10:40 PM
Which foam for interior cushions? jephotog Gear & Maintenance 7 08-26-2009 08:35 PM
Boat Cushions and Foam j1budo Gear & Maintenance 15 02-23-2007 02:42 PM
Closed cell foam cushions Fishboat Gear & Maintenance 4 02-03-2004 05:19 PM
