adhesive for foam (DIY cushions) - SailNet Community
 6Likes
post #1 of 14 Old 07-05-2014 Thread Starter
Looking for a good adhesive for sticking together pieces of foam.
A sheet of foam was cut up for the cushions. And, a couple of pieces need to be put together to make a whole. Is there something like a 4200 but for foam to foam?
andyselzn is offline
post #2 of 14 Old 07-05-2014
deltaten's Avatar
Send a message via Yahoo to deltaten
Re: adhesive for foam (DIY cushions)
Goodyear Plio-bond
andyselzn likes this.
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #3 of 14 Old 07-05-2014
72 C&C Corvette
CorvetteGuy's Avatar
Try elmers spray adhesive,, expriment with a small left over piece first.
CorvetteGuy is offline
The Following User Says Thank You to CorvetteGuy For This Useful Post:
andyselzn (07-05-2014)
post #4 of 14 Old 07-05-2014
69' Coronado 25
socal c25's Avatar
Dock
Use a 3M product, look at their line of stuff and find what best suits your need, I know they make one for foam but you need to know what type of foam you have to achieve the best results.
"There are those that stand at the shore looking to the sea, wondering, and there are those standing at the helm looking back at shore, knowing." - Kurt Leisenfelder
"Fiberglass shells that let us breathe, let us smell, keep us from going numb"- Kurt Leisenfelder
My Avatar is a pic of my son - Jan 19, 2014.
socal c25 is offline
post #5 of 14 Old 07-05-2014
Sailrite has good information here:
In addition to the adhesives they mention, I've also used in a pinch 3M Super 77 spray adhesive, which is readily available in hardware stores and Home Depot.
RichH and andyselzn like this.
RobertKWFL is offline
post #6 of 14 Old 07-05-2014
Upholstery cement (spray) from any crafts store.
You mention sticking pieces together...I hope that means horizontal seams, not vertical ones. Vertical seams would tend to come apart regardless of the glue, as the foam tears away from it.
hellosailor is offline
post #7 of 14 Old 07-06-2014 Thread Starter
@hellosailor : can you please explain what you mean by horizontal vs vertical seam?
We are trying to maximize foam use. We have one L shaped large piece. To make it a rectangle, we were planning on sticking two equal sized pieces side by side to complete the rectangle from the L.
post #8 of 14 Old 07-06-2014
This stuff:
Sailmaker's Supply carries it, and it's what they use in the shop
Nice tute on foam glueing
How to Glue Foam Together - DIY Foam Cushion - Seat Upholstery
Multihullgirl is offline
post #9 of 14 Old 07-06-2014
Sea Sprite 23 #110 (20)
mad_machine's Avatar
horizontal.. like a sandwich. If you glue two sheets of foam together as if they were naturally laying atop each other, the seam will not come apart. if it is vertical (end to end) the stress of sitting, getting up, and moving about on the cushion will eventually pull them apart.
If I were to need to glue foam end to end, I would stagger the pieces, like how they do brickwork. this way you have horizontal seams also holding it together
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
The Following User Says Thank You to mad_machine For This Useful Post:
andyselzn (07-07-2014)
post #10 of 14 Old 07-06-2014
Andy-
As Mad said. If the seam is like the ham in a sandwich, when you sit on the cushion all you do is press it together. It the seam is vertical, like the cut when you slice a sandwich in two, then every time you sit on it, you shear the two pieces apart. Actually, you will be shearing off the foam from the adhesive, because they aren't fused together, they are just glued, and each bubble in the foam tends to tear apart from the neighbors, even before they get old and brittle.
Making two pieces into a jigsaw puzzle, or uncutting a sandwich...I'd just be reluctant to do it.
The Following User Says Thank You to hellosailor For This Useful Post:
Foam for interior cushions?? Adele-H General Discussion (sailing related) 33 01-06-2013 08:09 AM
Boat cushions from stock foam xluke Gear & Maintenance 10 04-24-2011 10:40 PM
Which foam for interior cushions? jephotog Gear & Maintenance 7 08-26-2009 08:35 PM
Boat Cushions and Foam j1budo Gear & Maintenance 15 02-23-2007 02:42 PM
Closed cell foam cushions Fishboat Gear & Maintenance 4 02-03-2004 05:19 PM
