Tayana 37: Coamings cut off - is this repairable? - SailNet Community
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Like Tree17Likes
Old 07-06-2014
afrinus's Avatar
afrinus is on a distinguished road
Looked at a Tayana 37 today. The current owner, in an attempt to fix a leak that according to him most Tayana's suffer from, cut off both cockpit coamings flush with the deck. This removed the mounting surface for the main whinches.
I wonder if this is repairable (to original aesthetics and strength) such that one would be able to rely on the winches staying in place in a blow.
Any suggestions and ideas on how to do such a repair from the astute membership will be appreciated.
Tayana 37: Coamings cut off - is this repairable?-20140706_104914%5B1%5D.jpg   Tayana 37: Coamings cut off - is this repairable?-20140706_104929%5B1%5D.jpg   Tayana 37: Coamings cut off - is this repairable?-20140706_105012%5B1%5D.jpg
"You can't cross the sea merely by standing and staring at the water" - Rabindranath Tagore
  #2
Old 07-06-2014
deniseO30's Avatar
Move over Joan Rivers!
Re: Tayana 37: Coamings cut off - is this repairable?
Oh My Gawd!
Well this is I guess how it should look
Yes it can be restored. Question is.. the teak may cost more then the owner is "paying" you to take the boat of their hands. What where they thinking? Is all I can ask! What a mess! How badly do you want this boat? Did they save the boards and the glass they cut without thinking?
My guess; they were thinking they hated the cockpit so small and wanted it less confining.
zeehag and Morild like this.
Denise, Bristol PA, Oday 30. On Tidal Delaware River, Anchor Yacht Club. New Website!
my current "project"!
  #3
Old 07-06-2014
afrinus's Avatar
On the positive side - this is the kind of boat I dream of, the price is pretty low (I think he understands the mess and subsequently dropped his price pretty low) and the boat is on the same lake I sail in.
The bad - he didnt keep the cut-off pieces - it sounds that it was cut into pieces to get it off - including the teak
It was not that he wanted a bigger cockpit. Apperently Tayanas have a "standard" leak - water get into the coaming, into the core of the deck and then run into the boat interior where it drips out on the freezer lid.
I believe the owner really believed the only way to address the issue was through major surgery...
  #4
Old 07-06-2014
tomandchris is on a distinguished road
Unless you are really into learning how to do this job, and develope the experiencxe as you go, get a good estimate on what it would take. My guess...to much. You may want to see what else he "fixed"'
  #5
Old 07-06-2014
socal c25's Avatar
69' Coronado 25
socal c25 is on a distinguished road
Jesus H. Christ.... WTF was he thinking.... Thats like doing a Hysterectomy to cure a tooth ache. If you can fix it great, if a boat yard does the repair (reconstruct) your probably looking a several thousand dollars.
"There are those that stand at the shore looking to the sea, wondering, and there are those standing at the helm looking back at shore, knowing." - Kurt Leisenfelder
"Fiberglass shells that let us breathe, let us smell, keep us from going numb"- Kurt (borrowed and modified from- Zookoff)
My Avatar is a pic of my son - Jan 19, 2014.
  #6
Old 07-06-2014
TQA's Avatar
TQA TQA is offline
Bombay Explorer 44
TQA is on a distinguished road
Easy repair. No point in using teak for the sides as it will be a paint finish. Teak for the top would be about 200 250 US$ per side.
I think I would through bolt a couple of blocks to transfer the winch loads below but it would most likely be overkill.
Might be good to talk to the designer.
Paging Bob Perry.
zeehag likes this.
  #7
Old 07-06-2014
Bristol 45.5 - AiniA
killarney_sailor is on a distinguished road
Looking on the bright side, he cut them off neatly. It is repairable. It might be worth buying an hour of Mr. Perry's time to get an idea of how best to repair this.
christian.hess likes this.
Finished the circumnavigation in early February in Grenada. Have to work on a book project for the next several months so the boat will be waiting for next year.
  #8
Old 07-06-2014
Sabreman's Avatar
Sabreman will become famous soon enough Sabreman will become famous soon enough
Some people shouldn't be allowed to buy tools. Seriously.
Morild likes this.
Sabre 38 "Victoria"
The Following User Says Thank You to Sabreman For This Useful Post:
BluemanSailor (07-07-2014)
  #9
Old 07-06-2014
harmonic is on a distinguished road
Not a hard fix just need a few carpentry and fibreglassing skills.Should be able to do it yourself for under a grand.Librarys a great place to start.
  #10
Old 07-07-2014
sailvayu's Avatar
sailvayu is on a distinguished road
Heres a thought, fabricate the replacements out of aluminum and then bolt them onto the deck. this would give the strength to hold the winches.
bobperry and christian.hess like this.
Capt. Wayne Canning, AMS
You may post attachments
You may edit your posts
to cut or not to cut. that is the question. captain jack Gear & Maintenance 44 12-28-2013 07:23 PM
So I am not sure I am cut out to be a sailor... yellowwducky Cruising & Liveaboard Forum 69 02-09-2010 01:04 PM
Cross Cut vs. Radial Cut Mainsail sailing320 Gear & Maintenance 5 07-27-2009 10:47 PM
To cut or not to cut, that is the question Omatako Seamanship & Navigation 44 03-28-2009 05:54 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
