Hydraulic steering for sailboat - Page 3 - SailNet Community
 1Likes
post #21 of 27 Old 07-14-2014
Closet Powerboater
MedSailor's Avatar
Re: Hydraulic steering for sailboat
Keep her for a while as is before making a major change likw that. You might get used to it or even like it.
Medasailor
MedSailor is offline
post #22 of 27 Old 03-23-2017
I have newly acquired a 40 foot sailing boat, the boat has a Vetus hydraulic steering system. It's a dual system so the boat can be steered from inside as well as outside.
It takes me 7 turns lock to lock, half the time I don't have a clue where the rubber is pointing. Manoeuvring in the marina is a nightmare. I was beginning to think there was something wrong with the system but from reading all the posts it appears it's quite normal.
Phillip is offline
post #23 of 27 Old 03-23-2017
I've got hydraulic steering, and like yours, it gives very little feedback.
The best solution I think would be an autopilot as the good ones have rudder angle indicators that give a visual indication of how much wheel you have on.
The other solution is to mark centre wheel with tape or a Turks head. The centre wheel Mark will give you a good indication anywhere in the first turn on the wheel. If you are using multiple turns for bold maneuvers (assuming right hand throttle) always keep your left hand at the centre wheel Mark and count out your turns out loud or to yourself. Always have a running count going and you will always know where your wheel is.
I use both methods, Comnav 1101 a Comnav 1101 autopilot with rudder angle indicators, Turks head at centre wheel and I count out my turns
Bay Hen 21, Prindle 16, Walker Bay 8
Arcb is online now
post #24 of 27 Old 03-23-2017
HI Arcb,
I do have the centre of the wheel marked, but when your doing 3 and a half turns each way, it can get a bit confusing. I don't have an auto pilot but I am happy to hear having hydraulic steering is a plus when fitting one.
My manual tiller fits into the top of the shaft and it's just behind the helm station, maybe if I make a pointer this would be a big help.
This is a first for me with the hydraulics, I will persevere with it for now and see how I get on.
Phillip is offline
post #25 of 27 Old 03-23-2017
A standalone rudder angle indicator can be installed ,doesn't need an autopilot.but that makes wiring and switches easier Often older hydraulics can slip a little so top spoke can be over there a spoke .
Capt Len is offline
post #26 of 27 Old 03-23-2017
Dirt Free
boatpoker's Avatar
Marking a kingspoke is pointless if two pumps are involved. i.e. Helm and autopilot pumps. The king position will change every time you engage or disengage the autopilot.
Never seen the need for a rudder indicator (I've always had hydraulic steering) as a slight twitch of throttle will tell me where the rudder is.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #27 of 27 Old 03-23-2017
I wouldn't say a kingspoke is pointless, even if it isn't centred it can be used as a focal point for counting turns on.
I am not saying it's the only method, but it is a reliable method. The boats I learned to drive on, bursts of power weren't always realistic/possible, so I prefer a rudder angle indicator and counting turns in the event of a rudder angle indicator failure. It definitely works. I always count my turns, that way I know where I am in the event of a failure and so I don't have to look down to know where my wheel is.
Shots of throttle also don't work to well when your sailing
Arcb is online now
Hydraulic steering sailboat jameswhitworth Gear & Maintenance 1 04-25-2014 07:26 AM
Hydraulic steering wookie Gear & Maintenance 4 12-05-2009 04:11 AM
Hydraulic or Cable Steering? windtraveler Gear & Maintenance 11 11-13-2009 02:05 PM
hydraulic wheel steering clarity36 Gear & Maintenance 6 07-14-2009 08:21 PM
Hydraulic Steering eyebbober Gear & Maintenance 0 09-22-2004 02:34 AM
