Hydraulic steering for sailboat - SailNet Community
 1Likes
post #1 of 27 Old 07-11-2014 Thread Starter
What are the pros and cons regarding hydraulic steering for sailboats? For example, can you feel the force on the rudder as you would with mechanical steering?
Thank you.
Ted
TedKurtz is offline
post #2 of 27 Old 07-11-2014
jackdale's Avatar
Re: Hydraulic steering for sailboat
Much of the "feel" is missing in hydraulic steering. I have used it on a boat with twin stations; that prevents marking a king spoke as well.
jackdale is offline
post #3 of 27 Old 07-11-2014
Courtney the Dancer
jrd22's Avatar
As Jack said there is almost no feedback with hydraulic steering. The plus is that there are no cables/chains to route which makes installation relatively easy and installation of a below deck autopilot is easy. You get used to the lack of feedback, it's not a deal killer for me. Our boat has both cable (cockpit) and hydraulic (inside station, there is a valve to turn to activate/deactivate), I prefer the cable for sailing but like both systems.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #4 of 27 Old 07-11-2014
Master Mariner
capta's Avatar
Of course, a failure in a hydraulic steering system would probably be unheralded and quite immediate, whereas with proper inspection, a failure on a cable system might be avoided.
I really like "feeling" the helm and wouldn't go hydraulic unless there just wasn't another cost effective route on a boat under 60 feet. If you are going with hydraulic, do install a rudder angle indicator.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #5 of 27 Old 07-11-2014
Closet Powerboater
MedSailor's Avatar
jrd22,
Ooooh you have both? That's awesome. I would love to have that. Get the feel at the upper helm (where you sail from anyway) and the added redundancy of both systems and the hydraulic at the lower station. Nice....
I have hydraulic on my new boat, and I think I'm going to miss the feedback that cable steering gives you. Though on the trial sail I didn't find it too different from sailing a raceboat with a really large wheel where the "feel" is diminished so much by the mechanical advantage.
MedSailor
MedSailor is offline
post #6 of 27 Old 07-11-2014
CaptainForce's Avatar
Sure, there's less in your hands, but that does not eliminate feedback. You do have the response of the boat, the lift of the rail, visual movements of rounding up or falling off, apparent wind, the hull to the wave...... Hydraulic steering requires you to use all the tools in the box, not just the tiller in your hands. For many it might take some time to adjust if they've not been using all the input.
Take Care and Joy, Aythya Crew
CaptainForce is offline
post #7 of 27 Old 07-11-2014
Closet Powerboater
MedSailor's Avatar
A good point about all the inputs. I'm looking forward to the change, in a way, because it will force me to use other inputs. Kind of like the trick of sailing blindfolded to get the "feel" of the boat.
Sailing blindfolded, with hydraulic steering, now THAT would be a trick!
MedSailor
post #8 of 27 Old 07-11-2014
Senior Moment Member
SloopJonB's Avatar
I've got hydraulics on my boat and I hate it - HATE IT. Numb, insensitive, slow - it has NO redeeming features, The only reason for using it on a boat is necessity - center cockpit, clearance issues, rudder loads too high for manual (in which case something else is wrong) and so forth.
In case you missed my point - IT SUCKS! BIG TIME!
Don't buy a boat with it - I'll never have another one.
SloopJonB is offline
post #9 of 27 Old 07-12-2014
jackdale's Avatar
Absolutely.
jackdale is offline
post #10 of 27 Old 07-12-2014
I've got hydraulics on my boat and I hate it - HATE IT. Numb, insensitive, slow - it has NO redeeming features, The only reason for using it on a boat is necessity ...........
I'll agree with much of what you say, although I'm far less passionate about the issue. I don't agree with the "slow" statement. The transfer of energy by hydraulic pressure is no slower than the mechanical linkage. I suppose that the "slow" that you refer to might be the time it takes a helmsman, without good anticipation, to interpret the need to correct steerage. A redeeming feature that you are not recognzing is power. Far less effort is required at the helm and this also means that there is far less mechanical effort required for an auto piloting device.
I totally agree with the "numb & insensitive" to the hands.
Hydraulic steering sailboat jameswhitworth Gear & Maintenance 1 04-25-2014 07:26 AM
Hydraulic steering wookie Gear & Maintenance 4 12-05-2009 04:11 AM
Hydraulic or Cable Steering? windtraveler Gear & Maintenance 11 11-13-2009 02:05 PM
hydraulic wheel steering clarity36 Gear & Maintenance 6 07-14-2009 08:21 PM
Hydraulic Steering eyebbober Gear & Maintenance 0 09-22-2004 02:34 AM
