Tig welders - Page 2 - SailNet Community
 1Likes
post #11 of 12 Old 07-15-2014 Thread Starter
Owned by Velcro
Ferretchaser's Avatar
Re: Tig welders
Well I need the AC for welding aluminum. With limited space on board, I don't want to keep 2 or 3 machines around, if I can find one that I can use for stick and tig welding from steel to stainless and aluminum. Tomorrow I am borrowing a welder to fix the outrigger on one of the shrimp boats. I just don't like to borrow or hire things out and rather use my own tools for a job at hand.
ATB
Michael
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Light travels faster than sound. That is why some people appear bright until you hear them speak!.
Ferretchaser is offline
post #12 of 12 Old 07-15-2014
Wingnut
Re: Tig welders
Depends what kind of amperage you are after, and wether you are doing a ton of aluminum.
If its only now and again, and you are mostly doing thin stainless, i would have a look at the miller maxstar stl. Its a dc stick/ tig machine. Dc tig welding aluminum works just fine, especially if you have helium. Expensive, but if your not doing much alu then its worth it.
If you insist on AC welding i would look to thermal arc for a cheaper tig only welder.
Sent from my HUAWEI Y300-0151 using Tapatalk
Dirtyfloats is offline
Stainless TIG Welding Equipment? matt2 Gear & Maintenance 5 03-25-2009 07:10 PM
