New ignition switch for Universal 5416 - Page 2 - SailNet Community
 7Likes
post #11 of 25 Old 07-14-2014
One of None
deniseO30's Avatar
Re: New ignition switch for Universal 5416
Oh Jim.. you forgot? I replaced the switch on mine last year even though I did the panel rewire a few weeks ago.
Cole Hearse simple 3 terminal on for Acc and Momentary for starter. Starter wire is yellow with red tracer.
Old,
new
And all you guys going to yell "wire nuts" shut up LOL
here's the panel with ALL new guages and wiring
Amega gauge
jimgo likes this.
My last project!
deniseO30 is offline
post #12 of 25 Old 07-14-2014
One of None
deniseO30's Avatar
Jim, now is a good time to look at the harness. The heavy wire for the glow plugs does not have a relay I did not take it through the switch. in the harness you will find a blue and black and red.. I'll betcha the insulation is melded and they are ready to short or burn.
jimgo likes this.
My last project!
post #13 of 25 Old 07-14-2014
Maine Sail's Avatar
Most of the ON/OFF key switches in Universal/Westerbeke panels are Cole Herse.... You can get them at any chandler..
jimgo likes this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #14 of 25 Old 07-14-2014 Thread Starter
Asleep at the wheel
jimgo's Avatar
I'm already planning on removing/bypassing the ammeter. I don't really need a voltmeter (I don't think) on this panel. So, I'll probably leave the ammeter in there but it won't be connected to anything.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #15 of 25 Old 07-14-2014
One of None
deniseO30's Avatar
Nice thing... gauges aren't all that expensive Jim. Good luck! (I'd wait until winter)
My last project!
post #16 of 25 Old 07-14-2014
deltaten's Avatar
Send a message via Yahoo to deltaten
OK; but is the "acc" term on the C/H switches a momentary contact *without* being on in the run posit?
Run-of-the-mill auto switches have the "acc" tied into constant on in "run" posit. Hate like the dickens to have plugs on whilerunning!
Havva helluvva time 'splaining that to (even) Kubota dealers when trying to source a new sw..
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #17 of 25 Old 07-14-2014
deltaten's Avatar
Is the acc./heater MC pole tied into therun side on C/H switch? Hate ta have my plugs lit while running!
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #18 of 25 Old 07-14-2014
One of None
deniseO30's Avatar
Del, this help any? I know many setups have the glow coils on the switch.
eherlihy likes this.
My last project!
post #19 of 25 Old 07-14-2014 Thread Starter
Asleep at the wheel
jimgo's Avatar
My glow plugs are separate from the ignition switch (sort of). The ignition switch has to be in the "run" or "accessory" position for the glow plug switch to work. The glow plug switch is a separate, momentary contact switch. You engage the switch (in my case, pull up on the switch) for 30 seconds or so, then let go and turn the key. I'm pretty sure that's basically what Denise's picture shows.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #20 of 25 Old 07-14-2014
One of None
deniseO30's Avatar
If you look closely Jim you can see the glow coil wire (yellow with fuse.) does not come off the key switch.. I thought about and saw no reason for all that power to go through the switch. I gave it allot of thought also and don't see how anything can go wrong if anyone would press the glow coil button and not start the engine. Could the glow coils stay on? it's just as possible through a key switch with contacts "welding" It's all been working perfectly too.
all information i found says any engine with more than 2 glow coils says, use a relay.
jimgo likes this.
My last project!
Starter for Universal 5416 jimgo Diesel 16 03-26-2013 10:00 AM
Ignition switch corrosion brokesailor Gear & Maintenance 0 07-14-2010 06:54 AM
ignition switch, alternator, ???? seaduced8104 Electrical Systems 3 06-03-2010 06:19 PM
Universal 5416 filters deniseO30 Gear & Maintenance 3 05-05-2009 10:50 AM
zinc in Universal 5416? wumhenry Gear & Maintenance 12 05-16-2007 04:01 PM
