What the heck is this? - Page 2 - SailNet Community
 2Likes
post #11 of 22 Old 07-14-2014
Re: What the heck is this?
Originally Posted by newhaul View Post
Looks like some kind of power converter/ regulator it has an on and off switch and internal fuse where do the white and green wires go to and any idea what the other side looks like? After blowing up the pic some I would say power converter leads 1&4 go to a meter and lead 2 says positive and lead 3 negative flip the switch and see what a multimeter says is the output.
Looks like function may be related to RF so is there a coax cable connected to the other side of the thing?
WGEwald is offline
post #12 of 22 Old 07-14-2014
Ignore it and go sailing, switch it on if you like, if it smokes, turn it off and repeat step one.
"Just call me TB"
capttb is offline
post #13 of 22 Old 07-14-2014
Maybe part of a thermostat system or equivalent?, if the boat has/had a heater or A/C of some sorts?
Maybe check with a meter for battery voltage & the "meter leads' for continuity. If there is no voltage with all accessories operating or a resistance reading on the meter leads, it probably isn't part of anything. Before ripping it out, take the leads off & if everything else continues to work, it is probably OK to remove it. Or, you can just leave it alone.
dabnis is offline
post #14 of 22 Old 07-14-2014
69' Coronado 25
socal c25's Avatar
Dock
Maybe for a refrigerator unit?
"There are those that stand at the shore looking to the sea, wondering, and there are those standing at the helm looking back at shore, knowing." - Kurt Leisenfelder
"Fiberglass shells that let us breathe, let us smell, keep us from going numb"- Kurt Leisenfelder
My Avatar is a pic of my son - Jan 19, 2014.
socal c25 is offline
post #15 of 22 Old 07-15-2014
hpeer's Avatar
There is no way to say what it is with the info provided.
However, consider this....
The meter wires are really small telephone wires, 22 or 24AWG. they can't carry much current.
The Batt wires look to be power INTO the devise as they are next to the fuse and ON/OFF switch. They too are small so it does not draw a lot of power.
At best it's a poor installation.
The ON/OFF switch is off. So it was not working before, and you didn't miss it, so it's likely not useful or something you want.
If you can get a pic of the other face and see what comes out there.
While I can't tell you what to do, I would rip it out. Gleefully. It would annoy me until I found out what it was.
My motto is be BOLD and ditch it. If I have ever been burned by this approach I have forgotten the incident.
If it's not working it can only cause trouble, if only to confuse you in the future.
hpeer is offline
post #16 of 22 Old 07-15-2014 Thread Starter
mbowser's Avatar
It certainly will be coming out, I can't stand anything but simplicity and this upsets the engine compartment's feng shui. I'm just curious what it is.
mbowser is offline
post #17 of 22 Old 07-15-2014 Thread Starter
mbowser's Avatar
Mystery solved, I got in there this afternoon and pulled it out along with a huge amount of wiring. On the back side it's clearly labeled and is some sort of control box for an old fathometer that I yanked out when I re-cored the cockpit.
Unfortunately, I got a little overzealous with the old wiring purge because I cut my VHF antenna cable. Oops!
mbowser is offline
post #18 of 22 Old 07-15-2014
That must have been a really old unit. Thanks for the feedback, always interesting.
Paul T
dabnis is offline
post #19 of 22 Old 07-15-2014
Coax can be spliced or fitted with new connectors and rejoined. The good news is, if it wasn't premium coax to start with and it was well over five or ten years old...it should be replaced anyway. And the antenna checked or replaced as well.
hellosailor is offline
post #20 of 22 Old 07-17-2014
Singlehander by Default
nighthawk's Avatar
Sooooo...What you're really saying is that you did a shoddy job of removing the old fathometer???
newhaul likes this.
Spencer
Laguna Windrose 22 "Wind Angel"
Catalina 16
Visit my blog--
~~When you decide to become a sailor, you start with a full barrel of luck and an empty cup of experience. The trick is to fill your cup before the barrel runs dry.~~
nighthawk is offline
What the heck do I do with the traveller? Gregrosine Learning to Sail 9 09-03-2013 02:43 PM
Where the heck is it! smurphny Cruising & Liveaboard Forum 18 01-19-2012 07:07 PM
this must have been one heck of a wave. cardiacpaul General Discussion (sailing related) 16 11-29-2006 11:21 AM
What the heck is 'gunkholeing'? VirginiaSailor General Discussion (sailing related) 9 07-27-2006 11:22 AM
