Inflatable Boat Airfloor Replacement with Plywood - Page 2 - SailNet Community
 11Likes
post #11 of 21 Old 07-15-2014 Thread Starter
Re: Inflatable Boat Airfloor Replacement with Plywood
Thanks for all of the feedback. Since there are no dealers where I live to buy a floor, nor have I seen inflatable parts for sale online or in the classifieds and necessity is the mother of invention, I am going to attempt this project. I will try making it out of 3/8" fir plywood and make sure it is all sealed really well and use some foam to protect the edges. I think using just one piece for the entire floor will make it simpler provided I measure twice , or more, and cut once. I'll let you know how it all turns out.
twomikes is offline
post #12 of 21 Old 07-15-2014
christian.hess's Avatar
please do! post pics! jajaja
thanks
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #13 of 21 Old 07-15-2014
Owned by Velcro
Ferretchaser's Avatar
By the way, I found the dead dink in a marina skip / dumpster. Sometimes it is worth having a look.
christian.hess likes this.
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Light travels faster than sound. That is why some people appear bright until you hear them speak!.
Ferretchaser is offline
post #14 of 21 Old 07-15-2014
islander bahama 24
newhaul's Avatar
BTW comoxvalley.in.craigslist.va fwiw
Illegitimus Non Tatum Carborundum.
newhaul is offline
post #15 of 21 Old 07-20-2014 Thread Starter
So I got the floor built using some plywood and a cedar 2x4 leftover from a fencing project. I ripped the 2x4 in half then ran a dado down the centre to fit over the plywood. Did lots of measuring and trial fits, cut a few angles and came up with this. If it doesn't work in the boat I will add on some sides and bottom for when I meet my maker.
twomikes is offline
post #16 of 21 Old 07-20-2014 Thread Starter
I covered the floor with some resin then painted it and it is ready to go into the boat tomorrow for its maiden voyage?
twomikes is offline
post #17 of 21 Old 07-20-2014
HANUMAN
RobGallagher's Avatar
Looks good. Keep us posted.
I'm on my second inflatable floor. Who would have thought my high priced Hypalon boat would have a PVC floor?
Defender.com sells some solid floors designed to replace inflatable floors/.
Good Luck!
HANUMAN
'88 C&C 30 MKII
NOANK, CT
RobGallagher is offline
The Following User Says Thank You to RobGallagher For This Useful Post:
twomikes (07-21-2014)
post #18 of 21 Old 07-21-2014
awesome job man that looks real strong! let us know how it goes
post #19 of 21 Old 07-21-2014
Chastened
Ajax_MD's Avatar
Two-
That looks fantastic except that it's a bit large to stow.
It could use some hinges or to be sectionalized in pieces.
1981 Tartan 33 #168
Ajax_MD is offline
post #20 of 21 Old 07-21-2014
Originally Posted by BubbleheadMd View Post
Two-
question,
if you use hinges in the middle how would you fix them(make rigid) once in place? would you simply use side peices(slats) like the 3 peice ply floors in older dinghies or is there something easier and simpler to do?
cheers
Inflatable plywood upkeep.. TommyD Gear & Maintenance 3 11-24-2009 09:31 AM
Building a small plywood work boat SVDistantStar Gear & Maintenance 11 10-06-2008 09:07 PM
BUCCANEER II 500 Inflatable Boat piggybeach Boat Review and Purchase Forum 0 07-27-2007 09:30 PM
Marine plywood VS. pressure treated (wolmanized) plywood duffer1960 Gear & Maintenance 8 03-03-2006 01:12 AM
Plywood replacement Gene4er Gear & Maintenance 0 10-29-2002 06:41 AM
