Inflatable Boat Airfloor Replacement with Plywood - SailNet Community
 11Likes
post #1 of 21 Old 07-14-2014 Thread Starter
I am pondering the idea of replacing the air floor, which has since had a catastrophic failure, with plywood and wondering if anyone has successfully attempted this. Aside from the airfloor, the rest of the 9 foot Maxxon inflatable boat is in reasonably good shape and a replacement tender is currently unaffordable. The boat usually sits either in the water or on the deck of our sailboat year round so I am not concerned with portability, i.e. folding it up for storage.
I am thinking of using the existing airfloor as a template to cut out a single piece of plywood and cover the edges with a rubber hose or Styrofoam swim noodle to prevent chafing. I am not sure of what type or thickness of plywood I should use, or if this idea would even work. Any suggestions or experience with this type of project is greatly appreciated.
christian.hess likes this.
twomikes is offline
post #2 of 21 Old 07-14-2014
christian.hess's Avatar
Re: Inflatable Boat Airfloor Replacement with Plywood
me too I need to make a plywood floor and looking for ideas on padding
hope you dont mind op
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #3 of 21 Old 07-14-2014
islander bahama 24
newhaul's Avatar
I have seen people that have good luck with pipe insulation also several use large rubber sheethed garden hose wrapped to protect from chaffing
Illegitimus Non Tatum Carborundum.
newhaul is offline
post #4 of 21 Old 07-14-2014
RichH's Avatar
I've done this. Be sure to SEAL the edges of the (exterior grade) plywood with epoxy. Best is to 'route out' a small amount of the inner plys along the edges and fill/fare with thickened epoxy. I used duct tape for chafe protection with no adverse effect to the hypalon.
christian.hess and twomikes like this.
RichH is offline
post #5 of 21 Old 07-14-2014 Thread Starter
Thx RichH, do you recall what thickness of plywood was used, and did you cut just one piece for the entire floor, or connect several smaller pieces together?
twomikes is offline
post #6 of 21 Old 07-15-2014
Remember you're a womble
PaulinVictoria's Avatar
If you don't need it right now, keep your eyes on the classifieds, I see wood floors come up every month or two.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #7 of 21 Old 07-15-2014
Why don't you just pop into a shop selling inflatables with plywood floors and have a look.
knuterikt is offline
post #8 of 21 Old 07-15-2014
JimsCAL's Avatar
My Achilles is a wood floor type. I would guess plywood is 1/2 inch. It's in four pieces which makes handling and storage easier. In addition to channels to make the pieces move together, there are stiffening channels that snap onto the sides. I have used the floor without the side stiffening channels at times as they are a pain to put in and it works just fine without them. Just a bit less stiff.
Edit: Measured the plywood and it's closer to 3/8". I suspect it's really 1 cm as the boat was made in Japan.
JimsCAL is offline
The Following User Says Thank You to JimsCAL For This Useful Post:
twomikes (07-15-2014)
post #9 of 21 Old 07-15-2014
If you Google around, there are many threads, not just here but elsewhere, covering this subject
Multihullgirl is offline
post #10 of 21 Old 07-15-2014
Owned by Velcro
Ferretchaser's Avatar
I have the plywood floor from a dead dink on the top deck and am going to cut it to size for our air floor KABOAT. Its only around 3/4 of the length of our current dink but no one sits up front there anyway.
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Light travels faster than sound. That is why some people appear bright until you hear them speak!.
Ferretchaser is offline
Inflatable plywood upkeep.. TommyD Gear & Maintenance 3 11-24-2009 09:31 AM
Building a small plywood work boat SVDistantStar Gear & Maintenance 11 10-06-2008 09:07 PM
BUCCANEER II 500 Inflatable Boat piggybeach Boat Review and Purchase Forum 0 07-27-2007 09:30 PM
Marine plywood VS. pressure treated (wolmanized) plywood duffer1960 Gear & Maintenance 8 03-03-2006 01:12 AM
Plywood replacement Gene4er Gear & Maintenance 0 10-29-2002 06:41 AM
