Need Help With Fix Up - SailNet Community
 4Likes
post #1 of 32 Old 07-17-2014 Thread Starter
I recently received of 13foot wooden boat from a family friend and to make it work I will need a bunch of help to make it operation able as it is my first time repairing a wooden craft. The boat was in poor condition due to rot In some areas(mostly the skeleton of the craft and the top covering), we have mostly cleared up the rot in the skeleton and are replacing the top. The bottom was replaced recently so that's not a issue, The boat needs to be refibberglassed so I need help with how do it and with what brand/type. Also I need to know whether or not to waterproof the inside or not and how to do so.
Fenex is offline
post #2 of 32 Old 07-17-2014
tommays's Avatar
Re: Need Help With Fix Up
Wood boat and fiberglass = a really bad idea
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #3 of 32 Old 07-17-2014
Dock
Check out the Boatworks Today youtube series:
https://www.youtube.com/user/boatworkstoday
A LOT of good fiberglass advice and how-to's. West Systems also has good stuff too. As far as fiberglass over wood...couldn't comment on that, mine was all glass to start with
1970 Islander Excalibur 26 - Retired
CharlzO is offline
post #4 of 32 Old 07-17-2014 Thread Starter
Tommays I have looked around the hull and there are clear signs of fiber glass or someother kind of covering around the wood also I was told it was previously fiberglassed so was it just Improperly constructed?
Fenex is offline
post #5 of 32 Old 07-17-2014
christian.hess's Avatar
what wood is it? some are built with a light layer of glass to protect against the elements
you could do just that, sand away all old glass get fresh wood exposed and seal withthicked epoxy or go ahead and glass with 2 layers or so
its not that its such a bad method its more that once water eneters its only a matter of time before delamination, core issues and water rot occurs like you already know.
if the wood is in bad condition then your options start to decrease and costs increase in order to fix.
sealing the inside(this could be epoxy and paint cheaply) is just as important as sealing the outside...
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #6 of 32 Old 07-17-2014
Pictures would be very helpful.
christian.hess likes this.
MarkSF is offline
post #7 of 32 Old 07-17-2014 Thread Starter
The wood is plywood(particular type I will have to look into), and about pictures I will have to take and post them later as it is night where I am.
Fenex is offline
post #8 of 32 Old 07-17-2014
thought so...thats probably how it was built...
Id seal up the insides, reinforce daggerboard trunk and certain areas...then lightly glass the outer hull...
thats about all you can do...
post #9 of 32 Old 07-18-2014
Siamese's Avatar
I'd burn it. Seriously. If a 13 foot boat is what you want, get yourself a used Butterfly, Sunfish, etc.. The boat you've described will probably need just a light coating of gasoline and a match.
Delta-T likes this.
Siamese is online now
post #10 of 32 Old 07-18-2014 Thread Starter
I see Siamese so you thinks it's not worth the effort?
Fenex is offline
How do I fix this? BarryL Gear & Maintenance 3 05-07-2012 06:17 PM
A bit of a fix Walt352 General Discussion (sailing related) 14 08-22-2010 04:23 PM
window fix marinoinPV Gear & Maintenance 3 02-18-2008 11:48 AM
On the hard and need a fix? phallo153 General Discussion (sailing related) 3 02-04-2008 01:45 PM
How do I fix this headliner? bestfriend Gear & Maintenance 12 07-23-2007 06:28 PM
