Powering hot water heater with dedicated 12v - SailNet Community
 2Likes
post #1 of 16 Old 07-26-2014 Thread Starter
Glad I found Sailnet
Bene505's Avatar
All summer long we don't hook to shore power. It would be nice to have even warm water for showering. And we have 540 watts of solar power, more than we need, actually.
Does anyone know if Raritan hot water heaters can be powered by 12v instead?
After doing some measuring, it looks like the 1100 watt heating element is a 13 ohm resistor. I could invert 12v to 120v AC and then step down 2:1 to 65 volts AC to drive the heating element at 277 watts. But solar panels can drive even low resistance loads, so it would be much simpler to go direct from panel to heater (or charge controller dump load to heater).
How about it, anyone know if there's a limitation that precludes this?
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #2 of 16 Old 07-26-2014
islander bahama 24
newhaul's Avatar
Re: Powering hot water heater with dedicated 12v
It would work on direct 12v however I would think rather poorly just like the old travel mate coffee pot I had in a truck had an adapter that the 120ac cord plugged into and went direct to he old CIG lighter it worked but rather poorly the may answer your questions better and provide an alternate that would work better 6 Inch 12 Volt DC Submersible Water Heater Element
Illegitimus Non Tatum Carborundum.
newhaul is offline
post #3 of 16 Old 07-26-2014
Master Mariner
capta's Avatar
There are 12 volt water heater elements made specifically as dump loads for windgens which might serve your needs. A quick search should find you the info.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #4 of 16 Old 07-26-2014
Solar shower works ok.
MedSailor and aeventyr60 like this.
fcsob is offline
post #5 of 16 Old 07-26-2014
Mermaid Hunter
SVAuspicious's Avatar
Agreed. Some even have both a 120VAC and 12VDC element. Call John at SVHotwire Enterprises Alternative Energy Products ? svHotwire - 727-943-0424 | svHotWire . IIRC there are elements for Raritan. I think Isotherm is a problem.
SVAuspicious is offline
post #6 of 16 Old 07-26-2014
Closet Powerboater
MedSailor's Avatar
Not what you asked for, but it could be an option. Portable cheap on demand propane heater. Plumb it to a big tank and leave the unit outside (because of CO concerns).
Coleman - Hot Water On Demand? Portable Water Heater
MedSailor
MedSailor is offline
The Following User Says Thank You to MedSailor For This Useful Post:
cptjak (07-26-2014)
post #7 of 16 Old 07-26-2014
Brad, someone posted a conversion formula for 120<>12v resistive heating loads, either here on on a certain other forum, a week or three ago. Basically, it is NOT just a matter of driving loads and resistance, the heating element wants to see a certain wattage and if you drop the voltage, you've really got to up the amps in order to still get heat out of the heating element.
In practical terms, you either want to apply the rate 120V or ideally, find a 12V heating element for it. There may be one, targeted for the RV market, that bolts right up. Raritan might know. If not, you might be able to have an adapter threaded up to make one fit.
hellosailor is offline
post #8 of 16 Old 07-26-2014
One of None
deniseO30's Avatar
build a solar water plate to heat the H20 should be easy enough Or just route black tubing in a loop. but fill it to the top, it should move via gravity/temp difference. It won't "Flow" if there is air in the plate or tubing.
My last project!
deniseO30 is offline
post #9 of 16 Old 07-26-2014
Was going to express my concept but thought ,'no ,they wouldn't be interested' But Denise is on a similar tract. My plan is to bypass the hot shower water up thru the deckhead into a black solar tank on deck. Tank heats and overflows back to shower head mixing with cold for optimum temp control. This assumes a pressure water system and a desire to wash.
Capt Len is offline
post #10 of 16 Old 07-26-2014
islander bahama 24
newhaul's Avatar
Here is a dedicated direct replacement 12 v heating element that meets all of Brad's requirements and a lot cheaper han a new heater 6 Inch 12 Volt DC Submersible Water Heater Element
newhaul is offline
The Following User Says Thank You to newhaul For This Useful Post:
MedSailor (07-27-2014)
Water Pump/Hot Water Heater/Breaker Trips DINKS14 Gear & Maintenance 5 03-10-2014 10:31 PM
need hot water heater twisted23 Gear & Maintenance 13 01-14-2011 11:57 PM
Continuous Hot Water Heater ArgleBargle Gear & Maintenance 6 10-21-2008 07:10 AM
hot water heater sailaway50 General Discussion (sailing related) 1 01-10-2008 09:29 PM
hot water heater firstafair General Discussion (sailing related) 12 11-09-2006 10:25 AM
