04-27-2006
No, I would still recommend glassing in the holes and then re-gelcoating. The problem with a plug is that you really do risk sinking the boat rather quickly.
The prop shaft is probably two inches in diameter, at near the very bottom of the main hull. The amount of water that would come in through that hole, if the "plug" ever fell out, would probably be enough to overwhelm what bilge pumps you have in a matter of minutes. Then your boat would quickly fill up and sink.
