Rub rail oxidation. - SailNet Community
post #1 of 11 Old 08-03-2014 Thread Starter
Rub rail oxidation.
Hello. Does anyone have any tips for preventing the "dripping" of white residue from my white rubrails which have become "chalky/oxidized" over the years. They are still very functional but I don't like the appearance of the white streaking down my hull. Is replacing them my only option? I'm just worried that the same thing will occur eventually. Has anyone tried any topical applications of any products to the rub rails to prevent this white residue from bleeding down the hull. Thanks in advance. (It's on an Ericson 30+ 1980 - I'm not sure but I assume they are the original rub rails - and I'm in sunny/steamy florida)
douglasb is offline
post #2 of 11 Old 08-03-2014
Re: Rub rail oxidation.
Not much info to go on but Cetol can be a great stabilizer. Light applications with a rag and with any lucky might end up looking like wood.
Capt Len is offline
post #3 of 11 Old 08-03-2014
What is the material?
tempest is offline
post #4 of 11 Old 08-03-2014 Thread Starter
Thanks Capt. Len, that might be worth a try. Tempest I'm not sure but I'm assuming vinyl. If I accidentally touch them my arms/fingers are just if I had touched white chalk.
I'll try to post some pics.
douglasb is offline
post #5 of 11 Old 08-05-2014
Try an acetone wash. It worked on my 1976 rub rail. Then, after cleaning put some armor all on it. Try the acetone in a small non-critical area to see how it reacts with the material on you boat.
John
ccriders is offline
post #6 of 11 Old 08-05-2014
Tanley's Avatar
John
This works very well to clean up the rub rail (not sure it will get rid of the chalk like surface though). Move quickly and don't spend too long on any one spot or the acetone will begin to gum up the rubber. Also, use a white rag as the color may bleed out of anything that has a dye in it and stain the rub rail.
Not sure what your topsides are painted with, but take care not to get acetone on them.
Tanley is offline
post #7 of 11 Old 08-05-2014
Delta-T's Avatar
Try Mr Clean Magic Eraser My understanding it is a 2000 micron flexible sanding block. You need to remove the oxidized layer.
If it is too shot, I'm sure a replacement can be had.
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
post #8 of 11 Old 08-05-2014 Thread Starter
Thanks for the replies. I'll try to tackle an area of rail soon and see if any of it works. I'll try to respond with results as soon as I have them. Thanks again.
douglasb is offline
post #9 of 11 Old 08-06-2014
rbrasi's Avatar
I repainted mine with Buoy paint made by Flexabar.
Before..
After wet sanding, prep and seams filled with 5200...
After.
Once cured, it holds up very well and no more chalk.
1968 Cal 2-30
Sandpiper 2
MDR
rbrasi is offline
post #10 of 11 Old 08-06-2014
I cleaned up some scuff marks with Wil-Bond, seems to get the oxidation off too.
Wilson Imperial
tempest is offline
rub rail ncsc Cal 15 09-18-2014 06:40 PM
Rebedding Mahogany Toe Rail & Rub Rail Finallybuyingaboat Gear & Maintenance 3 03-15-2009 09:28 AM
Rub rail brak Gear & Maintenance 4 05-06-2008 03:33 PM
Toe Rail And Rub Rail C&c FRANK PALERMO General Discussion (sailing related) 1 10-08-2006 09:14 PM
S-2 Rub Rail Hymie Gear & Maintenance 1 10-27-2004 08:44 PM
