another a sail question - SailNet Community
 1Likes
post #1 of 17 Old 08-04-2014 Thread Starter
I have a line on the bow of my boat about a foot and a half long with a shackle on it. Is this what the po most likely used to fly his spinniker? I never have yet and I know alot of folks use poles but never noticed anyone using a line?
abrahamx is offline
post #2 of 17 Old 08-04-2014
mitiempo's Avatar
Re: another a sail question
Probably used to raise the foot of the jib off the deck.
Brian
mitiempo is online now
post #3 of 17 Old 08-04-2014
Or the tack for an asym spinnaker.
bvander66 likes this.
Jeanneau 54DS
Minnewaska is offline
post #4 of 17 Old 08-04-2014
If he used an asymmetrical spinnaker this line could be used to attach the foot to the boat. Did the spinnaker come with the boat? If so, is it a traditional or asymmetrical?
Boomer14 is offline
post #5 of 17 Old 08-04-2014
RichH's Avatar
Could be part of the tack line for an asymmetrical spinnaker
if the boat uses hank-on jibs it could be part of the jib's cunningham / downhaul 'jack line'. The cunningham used to affect sail shape; the downhaul jack-line to get the sail down without having to go to the bow when dousing.
RichH is online now
post #6 of 17 Old 08-05-2014
formerly 'BoatyardBoy'
SailRedemption's Avatar
We use a line similar to this on the boat I race on. We call it the "frackulator". Use it for sailing downwind. We attach it to the jib halyard, then crank down on the halyard. This, after easing the back stay, pulls the mast forward to get a bigger shoulder on the spin, I assume. So if the previous owner raced, he may have used that for this reason.
SailRedemption is offline
post #7 of 17 Old 08-06-2014 Thread Starter
I believe its just the attachment point for the a sail tack.
abrahamx is offline
post #8 of 17 Old 08-06-2014
Maine Member
BELLATRIX1965's Avatar
Yup, Sounds like a tack line for an asym spinnaker to me too!
BELLATRIX1965 is offline
post #9 of 17 Old 08-24-2014 Thread Starter
So I'm still a tad confused? Do I just attach this line to the tack or, I also have a tacker/strop, to go around my jib furler. do I use the tacker and attach the line to that. The line is about a foot and a half long and attached to a fixed point. or do I want a tack line that is led back to the cockpit so I can use the tacker and raise and lower the tack? Still have not raised the sail yet but might get a chance to today. If I use the tacker and attach said line to it , the tack would be about a foot and a half up the furler, if I just use that tack line alone then the tack would be about a foot and a half off the bow of the boat or I could use the tacker and attach a new tack line to it and through a block and back to the cockpit and be able to adjust the tack however I want. Just trying to see how the prievous owner was using it although he was in his upper 80's and some people I met that knew him said he never even used the spinnaker once.(brand new sail for me). Any help appreciated. I'll get a pic up later today.
abrahamx is offline
post #10 of 17 Old 08-24-2014
You can attach a line to the Boot ( Tacker) that goes around your furled head sail It doesn't have to be a fixed length allowing you to adjust the height.
It sounds like the OP simply set it up at the height he wanted and left it.
You can adjust at the bow, or bring it back..up to you.
tempest is online now
sail question! NewportNewbie General Discussion (sailing related) 25 06-04-2012 06:20 PM
Sail Question rwendt Gear & Maintenance 7 05-09-2012 07:47 AM
A Question for sail hlmffsailmaker General Discussion (sailing related) 4 04-22-2010 09:20 AM
Old Sail Question pirateofcapeann Gear & Maintenance 0 08-03-2009 09:08 PM
question for those who know how to sail jer1312 Boat Review and Purchase Forum 7 06-06-2001 04:36 PM
