Buying an outboard (22 seafarer) - Page 2 - SailNet Community
post #11 of 14 Old 05-05-2006
For a boat of that light displacement, any more than 5 hp is, in my opinion, too much. The light weight of the ever-more-efficient 2 strokes is an advantage, along with lower initial cost, while the oil mixing issue remains a bit of a pain.
Two other points:
Many of the small (5hp and less) motors are made by the same manufacturer regardless of the brand (eg - Merc & Nissan 5 hp both made by Tohatsu.) Interestingly Nissan offers twice the warranty.
While the exhaust at the prop can be a problem in reverse, many of these small motors allow 360 degree rotation, allowing you to "Back up" with the motor spun around in FWD gear - no exhaust in the prop.
Faster is online now
post #12 of 14 Old 05-06-2006
It might be one more option to take into considderation.
Wold you be in need of battery charging? No utboard charges very good, but at least it may provide som extra for navigation lighs etc. Check if the engine at least have the possibility to be equipped with a charge system. Below 8 hp that is rather rare.
haffiman37 is offline
post #13 of 14 Old 05-16-2006
Instantilt?
If your SF22 has the "instantilt" option - ie the motormount is in the well - you need to look for a 9.9 HP Johnson/Evinrude. This particular motor has an extremely compact powerhead and the Instantilt option was built around that one motor. The 9.9 is more than adequate for almost all situations.
Jim
Phoenix - SF23
tenn_squire7 is offline
post #14 of 14 Old 06-01-2006 Thread Starter
MZDANOW
THANK YOU!!! Everyone who posted their thoughts, I really appreciate your help. It turns out I went with a SUZUKI 4-stroke, DF9.9. Its got an electric start (and pull start), its got a battery charging coil as well as the proper shaft length of 20". I'll update with my results after launch - thanks again!!!
MZDANOW is offline
Looking for an used mainsail for Seafarer 24 HenryNguyen Gear & Maintenance 8 08-11-2012 05:02 PM
Seafarer 29 matoqui Boat Review and Purchase Forum 9 08-06-2011 05:20 AM
Outboard motor controls waltzingmatilda Gear & Maintenance 3 05-05-2010 09:08 AM
Seafarer info chrisgranger Boat Review and Purchase Forum 4 08-13-2007 02:20 AM
Outboard: Buying, Type & Fitting omega001 Gear & Maintenance 11 11-10-2006 10:09 AM
