Buying an outboard (22 seafarer) - SailNet Community
post #1 of 14 Old 04-28-2006 Thread Starter
MZDANOW
Question Buying an outboard (22 seafarer)
I do not know anything about engines... I intend to buy a new engine with a nice warranty, but I have no idea where to start. 1) what brand? 2) what size motor?
BOAT- 22 Seafarer, LOA 21'8", LWL 18'4", BEAM 7'5", DISPLACEMENT 2400 lbs
UPDATE!!!!
THANK YOU!!! Everyone who posted their thoughts, I really appreciate your help. It turns out I went with a SUZUKI 4-stroke, DF9.9. Its got an electric start (and pull start), its got a battery charging coil as well as the proper shaft length of 20". I'll update with my results after launch - thanks again!!!
LAUNCH!!! 6/17/2006 WOW!!! This engine has changed my life.. I cannot believe what a piece of garbage my old motor was! Docking is an absolute DREAM, and its light --- not to mention that the electric start is AWESOME!!!
MZDANOW is offline
post #2 of 14 Old 04-29-2006
any of the small four-stroke outboards would do pretty nicely for a boat that size and mass. Honda makes a nice 9.9 HP as well as a nice 20 HP. The 20 is power tilt... the 9.9 is manual.
sailingdog is offline
post #3 of 14 Old 04-30-2006
Outboard for 22 Footer
I had a two-stroke Johnson 9.9 long shaft motor on a Catalina 22 about the same size as the boat you mention that worked well, but an acquaintance had a 5 HP four-stroke on a Catalina 22 that also worked very well. A 20 HP is probably way more than you need (and much more expensive).
SailinJay is offline
post #4 of 14 Old 04-30-2006
sailandoar's Avatar
Be careful about buying too big an engine.
Tendency is always to buy a very large engine for the 'get home against all odds no matter what current/ wind/ or storm'. Try to avoid that. 22' is a tiny boat (in that is very senstive to changes in trim ballast) and a big engine will change trim a lot and dramaticly affect sailing ability. If you do get a huge tugboat sized outboard then at least be sure to have some shifting ballast (maybe 150lb lead shot in bags) so that in spite of your weight and engine's weight you can get the boat back on her proper water line. That makes a HUGE difference when trying to REALLY sail. IF conditions are so bad that you cannot make progress than be prepared to anchor and wait. That's asking too much for most folks I realize!
If you want a power boat that sails then get a motor sailer. They are a great choice and some very nice small ones are made, but try not to hang about 75lbs on the extreame end of a tiny 22' vessel.
Ideal would be a 2-4 hp light weight with a VERY long shaft (25" to 30"). Unfortunatly, 25" seems to be the longest standard shaft and they are rare. 20" is usually sold as LONG shaft. Years ago I had a Tohatsu 8hp w/ 25" shaft and alternator and it was a good engine but heavy (64lbs) and that was on a 26 foot pearson (old full keel - Carl Alberg type). It was a bear to get on and off even for a 40+ year old in good shape.
These days my favorite engine is 2hp honda 4stoke air cooled that I can lift with one hand and is very easy to mount most anywhere. The shaft is only 20" but as there is no water pump in the lower unit it is theoretically easy to make an extension to lengthen the shaft/lower unit, so that is a fantasy project for me. When sailiing, (20' marshall cat boat)I have a good anchor and line/chain and take water, a sandwich and good jacket so as to be prepared to be stuck for a bit sometimes, SELDOM EVER HAPPENS, and we have some 3 to 4 knot currents in the Cape Fear River.
See Also:
http://www.oarclub.org/
Check Out this book ( 10 STARS !!!)
Wind and Tide: An Introduction to Cruising in Pure Sailing Craft
By Jerome W FitzGerald
sailandoar is offline
post #5 of 14 Old 04-30-2006
foxglove's Avatar
9.9 hp drives my 26' boat just fine
I have a 26' macgregor that displaces about 4000lbs when ballased and provisioned. At full throttle, I lose control of the boat. It wants to climb above the bow wave and go on plane. Of, course, its hourglass hull-shape won't allow that so it careens out of control.
I use to have a 21' Macgregor with a 4hp engine which powered it just fine.
Max
foxglove is offline
post #6 of 14 Old 04-30-2006
I'd have to agree, that the 20 HP is probably overkill... The 5 HP Honda is only 62 lbs., but only has a 20" shaft, the 9.9 HP is 107 lbs., and has a 25" shaft. However, the 20 HP is only 1 pound heavier than the 9.9 HP outboard. So there really isn't much of a weight penalty if you want to go for the more powerful engine.
post #7 of 14 Old 05-04-2006
resdog's Avatar
The last thing you want to do is hang 100 lbs on the transom of any 22 ft. boat. The new 2-stroke outboards are much cleaner burning these days and significantly less weight than a 4-stroke. As far as a recommendation...I'm using an 8 hp Nissan that runs well on a 24 ft Beneteau. The only thing I can say about it is that no one except a Nissan dealer caries parts for it. That's a pain.
I used a little 4 hp Johnson along time ago on a J24 that did an adequate job. I don't have a definitive choice as to brands, other than stay light-weight.
resdog is offline
post #8 of 14 Old 05-04-2006
where are you going
I used a 4hp suzuki on the back of a j22 for six years, taking the boat down the Jersey Coast, Deleware Bay, and alll over the Chesepeake at hull speed. It was small enough to remove easily and never needed anything but plugs and washing. I mounted it on an adjustable bracket and it was a dream. 20hp would be silly. As with any sailboat, using tides and the sails is the fun part.
Michael B
devildad is offline
post #9 of 14 Old 05-04-2006
What brand and type 2/4 stroke is less important. Choose one that has a good low pitch/high trust propeller and a system that does not suck the exhaust into the propeller when reversing! The best propeller so far I have found is the one for the Johnson 9,9/15 that even fits the 4-strokes!
haffiman37 is offline
post #10 of 14 Old 05-04-2006
i know a fella who had a old pontoon boat around 20ft with a 9.9 on the back- believe it or not- he said it barely moved with a couple guys on it- but they used the 9.9 because it kept it in a different insurance class (or something to that extent) there is good reason they make a 9.9 hp engine, and not a ten- insurance or legal cutoffs. just a thought... i would check out the difference- if there is any.
onojmai is offline
Looking for an used mainsail for Seafarer 24 HenryNguyen Gear & Maintenance 8 08-11-2012 05:02 PM
Seafarer 29 matoqui Boat Review and Purchase Forum 9 08-06-2011 05:20 AM
Outboard motor controls waltzingmatilda Gear & Maintenance 3 05-05-2010 09:08 AM
Seafarer info chrisgranger Boat Review and Purchase Forum 4 08-13-2007 02:20 AM
Outboard: Buying, Type & Fitting omega001 Gear & Maintenance 11 11-10-2006 10:09 AM
