Bottom paint - Page 2 - SailNet Community
 5Likes
post #11 of 15 Old 08-08-2014
Bring On The Wind
CatMan22's Avatar
Re: Bottom paint
My boat looked similar to yours a month ago, I took keel off, sand blasted, epoxied, faired and painted it, sanded and painted the bottom, did not go through gelcoat. Heres a couple before and after photos.
AlaskaMC likes this.
S/V CatManDeux
Catalina 22
"hark, now hear the sailors cry,
smell the sea, and feel the sky
let your soul & spirit fly, into the mystic..."
Van Morrison
CatMan22 is offline
post #12 of 15 Old 08-09-2014
Re: Bottom paint
Originally Posted by ianjoub View Post
Should I put the outdoor oil based primer and top coat on top of the barrier coat, or instead of the barrier coat?
Barrier coats are for boats that spend a lot of time in the water. If you are not going to use antifouling paint because you intend to haul the boat after every use, then I would forego the barrier coat, given that the gel coat is in decent condition. Spend that money instead on something you actually use, like a new sail.
John
TQA likes this.
ccriders is offline
post #13 of 15 Old 08-17-2014
Re: Bottom paint
I purchased a new to me boat as well and the bottom looks very similar to the OP's. Is the best way to prep for new paint to sand the bottom and then paint? Also, what is the difference between barrier coat and bottom paint? Personally, I will be in for 6 months at a time in fresh water.
Cincy020 is offline
post #14 of 15 Old 08-17-2014
Re: Bottom paint
Cincy...There's a lot of information regarding this multi-step process on the Boat US Website:
There are also the paint manufacturers sites: like Petit and Interlux; take some time and check them out.
This is just one article: Boat Bottom Paint - BoatTECH - BoatUS
To briefly answer your question yes..you should sand the bottom to remove any peeling or chipping paint, but you want to be careful not to go so far that you damage the gel coat if it's still intact.
Barrier coat's goal is to keep moisture out, but it can also trap moisture in. So the hull should be clean and dry. Bottom paint is used to prevent marine growth, however it is not impervious and will allow moisture in. So, it's often desirable to barrier coat and then apply bottom paint. Then you maintain the bottom paint.
This is, of course a very simplified summary. The actual process and procedures will vary dependent upon how neglected your hull and keel are and if there are any blisters that need repair or any fairing that needs to be completed.
If doing the keel it's best to take it down to clean, solid, shiny metal, fill, fair, barrier coat and bottom paint.. if it looks like the OP's keel.
There are also many variations of bottom paint. http://www.pettitpaint.com/fileshare...painttypes.pdf
You might want to ask around your marina and see what others have success with.
tempest is offline
post #15 of 15 Old 08-17-2014
TQA
Bombay Explorer 44
TQA's Avatar
Re: Bottom paint
Yes, I am not at a marina. I have the boat at my auto repair shop.
Instead.
An epoxy barrier coat will do just fine on it's own.
Something like Sherwin Williamss Fast CladŽ Brush Grade Epoxy.
TQA is offline
Don Casey: Paint Waterline Stripe with Bottom Paint asdf38 Gear & Maintenance 23 03-05-2016 06:50 PM
Paint thinner for soft ablative bottom paint jameswilson29 Gear & Maintenance 7 11-26-2012 12:56 PM
Bottom paint prep, chipped paint josrulz Gear & Maintenance 16 02-14-2010 08:24 PM
Bottom Paint billangiep Gear & Maintenance 2 02-23-2008 07:12 AM
Bottom Paint PBzeer Gear & Maintenance 2 05-04-2003 07:11 AM
