jib sheets + clew - SailNet Community
 5Likes
  • 2 Post By SchockT
  • 1 Post By hriehl1
  • 2 Post By hriehl1
post #1 of 9 Old 08-08-2014 Thread Starter
KejaGrad's Avatar
jib sheets + clew
Hi,
Question from a novice sailor with two hanked on jibs:
A few times now I have had to switch from #1 to # 3 head sails while out on the lake.
Thus far, I have been tying the jib sheets directly to the clew. Works fine, but I am looking for an easier system (not a fuller).
Any suggestions on a type of line, knot or system that would allow me to easily attach sheets to either sail and easily switch sails.
Thanks.
KejaGrad is offline
post #2 of 9 Old 08-08-2014
Remember you're a womble
PaulinVictoria's Avatar
Re: jib sheets + clew
Soft shackles. Or two sets of jib sheets.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
The Following User Says Thank You to PaulinVictoria For This Useful Post:
KejaGrad (08-08-2014)
post #3 of 9 Old 08-08-2014
SchockT's Avatar
it takes 3 seconds to tie a bowline....what could be easier?
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
The Following User Says Thank You to SchockT For This Useful Post:
SailRedemption (08-12-2014)
post #4 of 9 Old 08-09-2014
I have a 2 foot long tail permanently attached to the clew of each headsail with an estar hitch (modified buntline hitch). The jibsheet is one continuous line, with the clew-tail tied to the midpoint of the jibsheet with a double sheet bend.
This allows quick sail changes, and no shackle hardware to take out a tooth.
christian.hess likes this.
hriehl1 is offline
The Following User Says Thank You to hriehl1 For This Useful Post:
bblument (08-09-2014)
post #5 of 9 Old 08-09-2014
bblument's Avatar
That seems to be a good idea.. thanks. I've always just used a cow hitch in the middle of my sheet (thread the midpoint loop through the clew, then both ends through that loop). However, this means having to take the lines completely in and re-run them when switching headsails. I'm going to try your tail method.
Barry
"Without question, the greatest invention in the history of mankind is beer. Oh, I grant you that the wheel was also a fine invention, but the wheel does not go nearly as well with pizza." - Dave Barry
bblument is offline
post #6 of 9 Old 08-09-2014
christian.hess's Avatar
have a pic of this please?
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #7 of 9 Old 08-09-2014
no longer reading SailNet
Alex W's Avatar
I agree. I use soft shackles on my boat and prefer them a little bit to a bowline because they are more compact. However we use bowlines on both boats that I race on and I they are pretty fast to change over (maybe 5-10 seconds per bowline when you make a compact knot).
Alex W is offline
post #8 of 9 Old 08-11-2014
Start with a 30 +/- inch rope for the tail at each jib's clew.
Attach to the clew with an estar hitch, making each jib's permanently attached tail. A bowline would probably do as well as the estar hitch.
Attach the tail to the continuous sheet at its midpoint with a double sheet bend. The double sheet bend is quick and easy to untie and retie if making a sail change. It has never slipped on me (a single sheet bend might). The sheets stay fed through the track cars when making a change, and there's no shackle flying about looking for a tooth to hit.
fryewe and christian.hess like this.
hriehl1 is offline
The Following 4 Users Say Thank You to hriehl1 For This Useful Post:
bblument (08-11-2014), christian.hess (08-11-2014), Minnesail (08-11-2014), SailRedemption (08-12-2014)
post #9 of 9 Old 08-11-2014
thanks man thats awesome...I dont feel like cutting my new jib sheet just yet till I test out the foresails I have and what works well...for now
like they say PIC IS WORTH A THOUSAND WORDS
thanks
Jib Bag and sheets rhr1956 Gear & Maintenance 19 02-12-2012 09:19 AM
Jib sheets on a Newport 28 jaschrumpf Gear & Maintenance 12 09-27-2008 07:45 AM
Jib sheets, In or Out?? Cope44 General Discussion (sailing related) 27 09-22-2008 02:11 PM
My new Jib Sheets US27inKS Gear & Maintenance 2 09-03-2008 02:22 PM
Jib Sheets PBzeer Gear & Maintenance 15 10-07-2007 02:35 PM
