Winch Free Spins - Page 2 - SailNet Community
 9Likes
post #11 of 18 Old 08-14-2014 Thread Starter
casey1999's Avatar
Re: Winch Free Spins
Thanks for all the input.
Winch is a Barlow #27 made in Australia. Pic below. One thing I was confused about is how to remove the winch. Apparently Barlow had a special tool, but without it you can stick a small rod into one of the two holes at top of winch and use handle to unscrew. Here are some documents I found concerning the winch. In the near future I will take apart clean and lube.
Links:
Drawings/Parts:
http://www.cheoyleeassociation.com/R...t%20Winchs.pdf
Dismantling Tool:
HUTTON-ARCO Yacht Winches
Parts Supply:
christian.hess likes this.
In the beginning, there was only water...
casey1999 is offline
post #12 of 18 Old 08-14-2014
christian.hess's Avatar
if you read that well casey, guess what barlow says to use on the pawls?
good ole sae30 oil...!!!!
and they top it off by saying to not use grease...and this isnt that uncommon advice
some people think greasing pawls even with light lithium grease is good when in reality its not necessary
now gears and other moving parts have at it but the faster the pawls move the better
the best method is to take them apart often and clean and lube...but most of us want the at least last 1, 2 years before removing them again.
food for thought
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #13 of 18 Old 08-14-2014
Senior Moment Member
SloopJonB's Avatar
Links:
Drawings/Parts:
Dismantling Tool:
Parts Supply:
If they aren't too seized up from neglect, that cap can be removed using a spring style deck plate key
SloopJonB is offline
post #14 of 18 Old 08-14-2014
Singlehander by Default
nighthawk's Avatar
Originally Posted by TQA View Post
The digital camera is your friend. Take pictures of EVERY STEP as you dismantle them.
Tape down the edges of the box around the winch. Those springs will try to escape and go for a swim.
If you have a cat watch that he does not disappear with a tinkly thing to play with. Ask me how I know this is important.
Crap!!!! I was going to rebuild my winches this weekend, but now I have to stop and go shopping for a cat! I'm glad I stopped in here today. Have you every tried to find a cat when you needed one on short notice!
Spencer
Laguna Windrose 22 "Wind Angel"
Catalina 16
Visit my blog--
~~When you decide to become a sailor, you start with a full barrel of luck and an empty cup of experience. The trick is to fill your cup before the barrel runs dry.~~
nighthawk is offline
post #15 of 18 Old 08-14-2014 Thread Starter
casey1999's Avatar
I got plenty of cats to choose from right in my own harbor. Hawaii has a huge feral cat problem.
post #16 of 18 Old 08-14-2014
tdw
Super Fuzzy Moderator
tdw's Avatar
Sloop .... I must try the lithium grease. If it does work as well as you say then I owe you a beer or ten.
btw ... when I said oil I did mean a light machine oil used very sparingly.
In the past when setting to work on a newly acquired boat I've always found the winches to be over greased with springs and pawls clogged up with the stuff. That is why I tend to accept the conventional wisdom, its always worked for me. I still don't think it is bad advice but I'm more than willing to try something new.
Not my thread but thanks for the advice.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #17 of 18 Old 08-14-2014
SloopJonB's Avatar
That pic reminded me of an old cartoon - a woman is standing in her front door and there's a pile of cats like that outside. The caption is "We hear that today is your 40th birthday and you're still single".
post #18 of 18 Old 08-14-2014
SloopJonB's Avatar
Try it like I described on one winch - I'll bet you'll be a convert. I've always found the winches on my "new" boats to be gunked up with old dried grease and dirt - hadn't been serviced for a decade or more.
Sailing spins lessons for life NewsReader News Feeds 0 08-27-2012 03:40 AM
Bristol 30 - Shaft spins, but no propulsion!? SpiKe22283 Bristol 6 10-24-2009 07:06 AM
