water leaking in oil - Universal Diesel 5411 - Page 3 - SailNet Community
post #21 of 22 Old 11-10-2010
Learning the HARD way...
eherlihy's Avatar
http://www.sailnet.com/forums/sailne...t-sailnet.html
4th paragraph, 1st sentence...
'gotta go. I'm making bread
eherlihy is online now
post #22 of 22 Old 11-24-2013
ericirvine's Avatar
Re: water leaking in oil - Universal Diesel 5411
The 5411 is a very similar block to mine, the 5416.
These engines have a history of overheating causing the cylinder head to crack, allowing water to mix with the oil. I think the common location for the crack is right in the middle of the head, between the two combustion chambers. Since the 5411 is raw water cooled, the passageways are prone to clogging up due to salt deposits, making this engine even more prone to overheating and the head cracking problem.
I am not sure if the 5411 has an externally mounted raw water pump or not, but if it does, it is driven off the injector pump camshaft. If the pump seals fail, water will enter the crankcase by getting past these seals.
HTH
Eric
Eric Irvine
1980 Bristol 29.9
Selkie
ericirvine is offline
Fresh water flush Yanmar diesel bgotbaum Gear & Maintenance 16 11-07-2011 10:42 AM
Overheating Universal 5411 JohnBassett Gear & Maintenance 20 05-20-2009 12:54 PM
leaking water tank?? bderosa Gear & Maintenance 5 06-06-2006 11:50 AM
Water Ballast/Manufacturer RSJ Boat Review and Purchase Forum 6 03-07-2002 06:59 PM
Universal diesel 5411 rmiille Gear & Maintenance 1 12-30-2001 07:01 AM
