Setting up a 24v solar charging system - Page 2 - SailNet Community
 1Likes
post #11 of 12 Old 08-16-2014
no longer reading SailNet
Alex W's Avatar
Re: Setting up a 24v solar charging system
Originally Posted by Minnesail View Post
Would there be an experimental way to find out? I suppose I could deliberately shade one panel and see how fast it charges.
A battery monitor (or even just an amp meter) will do the job and give you a good idea of how much charging you are getting out of the system.
On my 30w panel if I shade one cell in bright sunlight the charging drops from over 2 amps to under 1 amp. If I shade two cells my amperage falls so low as to be nearly useless. This is with a Genasun MPPT.
Alex W is offline
The Following User Says Thank You to Alex W For This Useful Post:
Minnesail (08-17-2014)
post #12 of 12 Old 08-18-2014
norahs arc's Avatar
Re 24 volt solar panels. In my area a 24 volt panel is about half the price per watt of a 12 volt panel -so you would be better off with a 24 volt panel for two reasons - cost per watt and you won't be needing to change voltage through a voltage converter which uses a fair bit of power. (Really noticeable on a low power system - which yours is considered.)
Re panels in the shade of the boom (or anything else) - US solar make a panel that uses older technology and results in a large panel for the output compared to the newer ones BUT IT WORKS BETTER THAN THE NEWER ONES when partially shaded and on cloudy, low light days. (I use these at home and on the boat - 64 watt on the boat, much more at home.)
Catalina 27 Aft. galley, dinnet L/O
Update - Sold Norah's Ark Buying A 24'Shark
Saint John NB
Canada
norahs arc is offline
The Following User Says Thank You to norahs arc For This Useful Post:
Minnesail (08-18-2014)
12v system and 24v system on 1 boat at same time? BigCatOne Gear & Maintenance 12 07-22-2016 04:46 PM
24v solar panel for 12v charging? Bene505 Electrical Systems 7 01-04-2012 09:44 PM
Tapping 12V from 24V System kaakre Gear & Maintenance 7 06-08-2008 08:34 PM
Getting confused on an electrical system - 12v, 24v, 115V, 220V... labatt Gear & Maintenance 7 10-08-2007 10:05 AM
Charging with Solar Power Kevin Jeffrey Gear and Maintenance Articles 0 07-28-2003 08:00 PM
