Mast weight - Page 2 - SailNet Community
post #11 of 12 Old 08-17-2014
Re: Mast weight
Less then 150lbs
ToppDogg is offline
post #12 of 12 Old 08-17-2014
Re: Mast weight
If you cut off the bottom 12 inch and weigh the chunk it will give you an idea of what you're dealing with. Actually the weight doesn't matter until you get it to the scrap yard. A Hi ab arm can lower it quick and safe. If it can't reach above the CG lash a block or barrel to the base and lower away. lashing the weight is to prevent kick out as you and a couple of buds hand o'vr hand it.
Capt Len is offline
Catalina 27 Mast Weight? SeaChanger General Discussion (sailing related) 8 05-22-2014 10:29 AM
Alumium vs wood mast weight? MedSailor Sailboat Design and Construction 20 12-13-2013 10:28 AM
Irwin 34 Mast Weight tfyoung Irwin 3 04-11-2011 01:07 PM
Mast weight on Catalina 22? ilikerust General Discussion (sailing related) 11 11-07-2010 01:05 AM
columbia 22 mast weight gulliver22 Columbia & Coronado 2 11-11-2008 08:13 PM
