The WTF challenge! - Page 2 - SailNet Community
 35Likes
post #11 of 53 Old 08-15-2014
christian.hess's Avatar
Re: The WTF challenge!
Originally Posted by MedSailor View Post
Am impact driver used in the first place sure would have helped avoid this situation.
Any thoughts on how to apply said impact driver to the gnadgered studs? Only one of them has anything left of a slot on the head.
MedSailor
in my opinion I dont think you have enough stud for the use(correctly of the impact driver) by placing it in the chuck, some very sharp vise grips after doing the heat treatment works better in this particular case
if you care to use the method I described
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #12 of 53 Old 08-15-2014
a huge ******* pair of pliers and a hammer? I don't envy you at all
MedSailor likes this.
Liveaboard on a 1980 36' Hunter
alctel is offline
post #13 of 53 Old 08-15-2014
Bristol 45.5 - AiniA
Get a new boat?!?
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #14 of 53 Old 08-15-2014
bblument's Avatar
MedSailor
Fairly easy, but not a high probability of success:
Use a dremel and cut a new slot
More difficult, but more likelihood of success:
Grind a flat surface to the top of the stud, then weld on a bolt head to the top of the stud.
MedSailor and christian.hess like this.
"Without question, the greatest invention in the history of mankind is beer. Oh, I grant you that the wheel was also a fine invention, but the wheel does not go nearly as well with pizza." - Dave Barry
bblument is offline
post #15 of 53 Old 08-15-2014
billyruffn's Avatar
A prize will go to the person who has the idea/technique that will successfully remove these bolts!
MedSailor
Try a little dab of C 4 on each one. Boom! No more bolts.
Where do I claim my prize?
billyruffn is offline
post #16 of 53 Old 08-15-2014
chucklesR's Avatar
Heat will expand the metal, not what you want.
Freeze it instead so it contracts, then penetrating oil; cut a X slot with a dremel or a hack saw and back them right out.
chucklesR is offline
post #17 of 53 Old 08-15-2014
well the issue you have some techniques that counter others
heat is in fact what you want if what you want is to wick in PENETRATING oil or the 50 50 mix I mentioned
heat also will crack and or melt any sort of epoxy or sealant or varnish or liquid that has migrated in the threads or not
heat and therefore the later CONTRACTION of the metal is what in reality releases the threads
if you do this more than a few times the heat thaw heat thaw is usually enough with combination of penetrating oil and some sharp vise grips to remove
last bit of advice
for those saying to cut a slot...if you do so on the stub only and especially on the ones that already had a drill hole in them you are setting yourself for the easiest crack ever
that part of stainless is extremely soft...plus you have already on most of those stubs bent and or expanded or softened the metal
the grip method compress the shaft as a whole and has a much much likelier chance of not snapping on you than the other methods provided you have used the heat method, wicking in the penetrant and most importantly
USE A COOL HEAD AND PATIENCE
peace
ps. med if you havent rebuilt any old engines before youll see that this is a walk in the park...jajajaja
post #18 of 53 Old 08-15-2014
last ditch(cause you need a welder) but 100 percent success rate...
a nice hex NUT(that goes over the stud) is the tried and true method
JimMcGee likes this.
post #19 of 53 Old 08-15-2014
Mermaid Hunter
SVAuspicious's Avatar
Good luck.
Heating up the remnants and letting them cool will help break the connection which is likely corrosion welded.
Someone (Popular Mechanics magazine perhaps?) did a comparison of penetrating oils. As I recall PB Blaster was the best commercial product but the 50/50 mix of ATF and acetone Christian suggested was better yet.
Hitting the stud with a hammer also helps to break the corrosion bond. Since you said you have access to the bottom you might try also beating the screws from that side with a hammer and a brass drift.
After all that ViseGrips (tm) might get them out. If not you choose between welding on a bolt head (as suggested above) or EZ-Outs (which aren't easy).
christian.hess likes this.
SVAuspicious is offline
post #20 of 53 Old 08-15-2014
Daniel - Norsea 27
Rhapsody-NS27's Avatar
Maybe it's me but the pictures look like they're hollow. I'm sure they're not though.
My idea is to cut the bolts flush to the surface, as close as you can get then find a hole saw and cut it out off-center from those bolts so you won't be drilling the studs themselves. Then, the same size hole saw to make a plug to fill the hole (mostly) then use fiberglass and epoxy to fill/fair it and then you can retap and place new studs, if you still need them.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is offline
WTF is this? ericb760 Gear & Maintenance 54 10-07-2013 02:52 PM
Wtf? Tim R. General Discussion (sailing related) 37 09-01-2012 12:22 AM
