Rust stains on non-skid - SailNet Community
 1Likes
post #1 of 13 Old 08-16-2014 Thread Starter
We have some rust stains on the non-skid near our bow. Any tips for removing them? Mr. Clean magic eraser and Clorox cleanup haven't worked.
Thanks.
"Pegu Club"
1977 Bristol 29.9
cthoops is offline
post #2 of 13 Old 08-16-2014
Warm Weather Sailor
Vasco's Avatar
Re: Rust stains on non-skid
Oxalic acid.
Rick I
Toronto in summer, Bahamas in winter.
Vasco is offline
post #3 of 13 Old 08-16-2014
Hush34's Avatar
Tidy Bowl toilet cleaner.
Hush34 is offline
post #4 of 13 Old 08-16-2014
jsaronson's Avatar
Sudbury hull cleaner
jsaronson is offline
post #5 of 13 Old 08-16-2014
AKA44's Avatar
Hey! I've got a few of those tiny, almost pinpoint rust spots scattered on my non-skid, too. Located only in the wettest deck zones. Decided they were't biological as even bleach didn't alter their appearance. So, is it a spot of rust? An errant grain of iron in the new sand/Awlgrip non-skid? Somehow exposed to moisture under the final coat of paint?
What does oxalic acid neutralize?
AKA44 is offline
post #6 of 13 Old 08-16-2014
JimsCAL's Avatar
Any acid should remove the rust stains. Oxalic is a good choice. Marykate ON and Off is available in any marine store.
JimsCAL is offline
post #7 of 13 Old 08-16-2014
rhr1956's Avatar
Barkeepers Friend is basically oxalic acid. It will get the rust out.
AKA44 likes this.
rhr1956 is offline
post #8 of 13 Old 08-16-2014
I use On&Off! Works great on waterline scum too. Don't get it on your clothes...
Bruce
Bruce B is offline
post #9 of 13 Old 08-16-2014
S/V Wyndwitch - Morgan 24
oysterman23's Avatar
Bruce
Hi Bruce and all. On off in the gel form is great for vertcal surface such as the scum line it also comes in a liquid which works great in a small garden sprayer. It is a combination of oxalic and phosphoric acids and is definitely best used with gloves....Most of the time a home mix of west marine oxalic crystals in warm water in a spray bottle with a dash of LA Awesome will remove most impossible stains need not be used at the concentration of On Off for most. That mixture i mentioned is one of the best combos for brightening/restoring weathered teak I've found and costs very little. Used with 3m pad of correct grade it shapes up beat up teak nicely without too much pain. Also kills any residual fungal activity in or on the wood.
oysterman23 is offline
post #10 of 13 Old 08-17-2014 Thread Starter
Thanks for the suggestions, everyone. On the boat now but the Barkeepers Friend is at home. I'll give it a try next weekend and if it doesn't work I'll make a trip to Defender.
"Pegu Club"
1977 Bristol 29.9
cthoops is offline
Rust stains at partners? L124C Gear & Maintenance 10 07-02-2015 12:22 PM
Removing rust stains from "Starboard" TakeFive Gear & Maintenance 19 12-21-2013 03:55 PM
Removing rust stains on sails harpguitar Gear & Maintenance 10 06-02-2010 03:10 PM
deck stains/green spots/and a little rust QuickMick Gear & Maintenance 6 11-05-2009 12:44 PM
Rust stains on sails tybert Introduce Yourself 0 07-02-2008 12:30 PM
