Inspecting fire extinguishers - Page 5 - SailNet Community
 8Likes
post #41 of 53 Old 08-20-2014
Once known as Hartley18
Classic30's Avatar
Dock
Re: Inspecting fire extinguishers
Originally Posted by knuterikt View Post
During the fire (that started in the engine room) on the MS Nordlys the CO2 system was not released because two of the engine room crew was not accounted for.
The two crew members was later found dead.
Sad, but true. This one was even worse: Westralia Board of Inquiry | Royal Australian Navy
The engine room really isn't a great place to be in a fire.
"Honestly, I don't know why seamen persist in getting wrecked in some of the outlandish places they do, when they can do it in a nice place like Fiji." -- John Caldwell, "Desperate Voyage"
Classic30 is offline
post #42 of 53 Old 08-20-2014
hellosailor's Avatar
I wouldn't say the non-refillables are lesser quality, they are built differently because they can be crimped shut, no threads needed to reopen them. As for making more trash...One way you toss it after five years, and the metal can be recycled, while the other way you generate wasted chemicals, wasted energy compressing new gasses, wasted fuel as it gets sent back and forth...Waste no matter how you slice it.
So since there's no requirement or reason for civilians to replace unregulated extinguishers every tear, I just don't.
hellosailor is offline
post #43 of 53 Old 08-20-2014 Thread Starter
Closet Powerboater
MedSailor's Avatar
But that's just it. That's exactly my question. It appears we boaters ARE all supposed to get our extinguishers all inspected and tagged OR for possibly lesser expense, buy 3 cheap new ones and throw them away every year.
Doesn't seem right, but that's what the survey says no?
All fire extinguishers without current inspection tags. Recommendation, have
extinguishers re-certified or replaced. IAW NFPA 302. **, ABYC A-4 AP 6.3 At one year
intervals, a full maintenance check should be made by a qualified fire extinguishing system service
facility in accordance with the manufacturer’s maintenance instructions. A tag should be attached
showing the date of such maintenance check.
MedSailor
MedSailor is offline
post #44 of 53 Old 08-20-2014
I thought someone pointed out that the referenced code did not apply to recreational boats?
Jeanneau 54DS
Minnewaska is offline
post #45 of 53 Old 08-20-2014
Med-
"...we boaters ARE all supposed to get our extinguishers all inspected and tagged ... that's what the survey says no?"
No, that isn't what the survey says.
"...IAW NFPA 302. **, ABYC A-4 AP 6.3 ..."
That means the surveyor thinks you must be in accord with the National Fire Prevention Association 302, which is a private industrial standard, not a law or a regulation. And the ABYC A-4 AP 6.3, which is another private recommendation, not a law or regulation, which we civilians can't even READ because the ABYC makes their money by selling their standards books. No peeking without paying.
So your surveyor is saying there are some highly regarded PRIVATE recommendations to spend money on tradesmen every year. Whooppeee! Can we say, "Not objective, has conflict of interest" there?
On the other hand, a company like Kidde, with big deep pockets and their name in flashing lights, would be in for a million dollar verdict in a lawsuit if the extinguishers they warranteed as good for six years without any attention, actually failed because of that. Wouldn't they?
One company (others too, I'm sure) is putting their money where their mouth is. The other? Yeah, right, they want you to spend money on the people who buy their books. Need it or not.
Call me a cynic, but if your surveyor had bother to use ENGLISH instead of JARGON, there'd be no confusion.
One of the mandates of the National Incident Management System, the umbrella for all FEMA/DHS disaster operations in the US, is "NEVER USE JARGON" because all it does is create confusion. Psychiatrists will tell you that jargon is designed to keep "them" ignorant and unable to understand "us". There's no excuse for it from a surveyor.
Tell him to rewrite the survey, and if he wants to include references to PRIVATE RECOMMENDATIONS for upkeep, to include those recommendations verbatim and complete. And to disclose any conflict of interests he may have, i.e. he has probably FUNDED the ABYC by buying their standards books. Or else he doesn't know what that standard reads, does he? Hmmmm.....
How does one say, "FUD!"
On Madison Avenue the MBAs used to say "Don't ---- on my head and tell me it is raining."
post #46 of 53 Old 08-21-2014
I might have missed something in this thread, but I had a chat with one of our senior VE folks and a fire extinguisher servicing company last fall, and summarized below is what I was told
For Recreational boats (no passengers for hire)
1) All extinguishers on boats must be USCG approved and rated (read the fine print if you are in the kitchen section of WalMart etc. ) and they must be mounted in the proper approved bracket.
2) Dry chem don't need to be inspected by a service agent annually (but should be checked by the boater a few times a season to make sure the gauge is in the green)
3) Liquid extinguishers such as Halon, Halotron, CO2 etc. must be serviced annually by an approved agent - the annual requirement for liquid extinguishers is because the liquid agent can leak out but the pressure can stay in the green (this happened to one of my Halon extinguishers that I had at home and did not service for several years, it was down a few ounces of liquid) - so the liquid extinguishers are weighed to make sure the proper amount of agent is still inside.
4) also the shells need to be hydrostatic tested periodically (I think it can vary from state to state - and is I think 5 years in Washington state)
For my boat I bought larger dry chem extinguishers than required and they are refillable, after 12 years two hydrostatic tests and several standard service checks (I take them in every couple of years (yes I grump a bit about the cost) and they are still in good shape.
nwsaildude is offline
post #47 of 53 Old 08-21-2014
aeventyr60's Avatar
Med,
I used to take my fire extinguishers to a place over on market street, downtown ballard. Think they had a "deal" for boaters. Five bucks was the charge. Not too spendy to be in compliance.
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #48 of 53 Old 08-21-2014 Thread Starter
Closet Powerboater
MedSailor's Avatar
Originally Posted by aeventyr60 View Post
Med,
Nice. That wouldn't be to bad at all.
Another thought I had was to buy all the expensive halon extinguishers from our local guy in town and see if he'd throw in several years of inspections as part of the deal. Wouldn't cost him anything and might secure my business.
Medsailor
post #49 of 53 Old 08-21-2014
Old as Dirt!
svHyLyte's Avatar
MedSailor
I endured several weeks of BS over our, then, 6 month old Kidda ABC Fire Extinguishers with our insurance company after a Surveyor (for an insurance survey) added his "opinion" that having our Extinguishers examined and tagged annually would be "wise" and quoting the same "Standard" in his "recommendations". Consequently, our insurer then insisted that we do so and sign a "certificate of compliance" to that effect to maintain our policy. Among other matters, we have Extinguishers in each cabin/compartment as well as an automatic dispenser in our engine compartment, no fewer than 6 including a CO2 cylinder on the main bulkhead in our Salon so this would not have been an inexpensive proposition. Our Fire Service company flatly refused to "tag" our ABC dispensers indicating that they were not subject to inspection and were good as long as the gauges were "in the green". (Kidda's own literature includes a guaranty of a 12 year service life.) The matter was finally resolved but not without aggravation.
Later, our insurance agent, who also happens to be a sailor, told me to tell any future surveyor that if he had "helpful" suggestions, to include them in a separate page not a part of the formal Report of Survey to avoid unnecessary issues.
FWIW...
PS: In addition to the Extinguishers, we also have Fire Blankets strategically located including one on the locker door directly opposite the galley. Having once had to deal with a galley fire in a malfunctioning alcohol stove, I can attest that these do work, very well.
svHyLyte is offline
The Following User Says Thank You to svHyLyte For This Useful Post:
MedSailor (08-21-2014)
post #50 of 53 Old 08-21-2014 Thread Starter
Closet Powerboater
MedSailor's Avatar
FWIW...
Sound's like you've been down the road that I'm on. I know that I'm going to have to comply with this because it's on the survey and insurance companies don't like interpretation, explanations or ambiguity. They like paper trails and compliance and such.
I may call up the surveyors at some point and have them come do a post-compliance inspection which I will send to insurance. Perhaps they'd be willing to modify their language so that it covers the safety aspects they feel are important, but isn't overly onerous on me.
I can see for example, that the recommendation to tag all extinguishers punishes you for carrying more than is required. How about a recommendation to inspect the USCG minimum and if I carry more I get bonus points??
I can also see your problem of the "uninspectable" extinguishers. Perhaps in my letter of compliance to the insurance company I will tell them I have replaced the current extinguishers with ones that don't require inspection. We'll see..... I DO plan to replace the 2x 10lb dry chem extinguishers on the boat. They're huge and heavy and that's a LOT of dry chemical. I'd much rather have more smaller bottles of clean agent extinguishers.
MedSailor
Re: Recharging fire extinguishers NewsReader Mass Bay Sailors 0 04-09-2007 05:15 PM
