Throttle won't hold position! - SailNet Community
 3Likes
post #1 of 14 Old 08-19-2014 Thread Starter
SailAway
maccauley123's Avatar
I have a Beneteau 361 which has a Teleflex single arm throttle to control both forward/reverse transmission and throttle. Photo attached. Overall it works fine except it won't hold position where I want it. I want to run the engine around 2800 rpm for cruising and the engine runs up easily but when I remove my hand from the throttle it pulls back by itself. Only seems to hold around 2000 rpm. I've tried tightening the set screw at the base of the throttle arm and this didn't do any good, still slips. Is there another adjustment I can do or replace a friction plate or something or am I stuck replacing the whole assembly?
You will regret the things you did not do, more than the things you did.
Get out there!
Saco Bay, Maine
2001 Beneteau Oceanis 361
maccauley123 is offline
post #2 of 14 Old 08-19-2014
weinie's Avatar
Re: Throttle won't hold position!
put a u-bolt or rope wire clamp on the cable. Tighten gently until tension is sufficient.
T37Chef and nccouple like this.
weinie is offline
post #3 of 14 Old 08-19-2014
Bristol 45.5 - AiniA
You can add a little clamp on top of the shielded part of the cable. You do it up just the right amount to add a bit of friction to the passage of the inside cable. Too much and the cable does not move freely, too little and it slips.. Just need to play with it (tightening 1/8th or a turn at a time). I have had the problem on two boats. In one case I got a special clamp (from Edson?) at great price. In the other case basically a tiny jubilee clamp for a couple of bucks at a boat store in Antigua. Both worked.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #4 of 14 Old 08-19-2014
Master Mariner
capta's Avatar
There should be two springs on the throttle connection to the fuel injection pump. I'm guessing one may be tired or have popped off.
facebook.com/svskippingstone
Our Videos;
capta is online now
post #5 of 14 Old 08-19-2014 Thread Starter
SailAway
The U clamp is a great idea, wish I had thought of it.
Get out there!
Saco Bay, Maine
post #6 of 14 Old 08-19-2014
no longer reading SailNet
Alex W's Avatar
My boat has the clamp to add friction, but the throttle still slips. As the engine warms up it gets enough friction to hold at 2800rpm.
I'll check to make sure that both springs are on there. Page 157-158 of the service manual explains how to inspect them. On my 2GM20F larger spring (main spring) should be 80mm long with 20mm of coils, and the smaller spring (secondary spring) should be 23mm long with 10mm of coils.
Alex W is offline
post #7 of 14 Old 08-19-2014
Actually what you want is a cable brake like this
TELEFLEX 044386 THROTTLE CABLE BRAKE
Note that the bolt in the picture is in backwards. The head of the bolt should contact the cable.
While cable anchor clamps will work they are harder on the cable sheath.
Brian
T37Chef likes this.
saillife is offline
post #8 of 14 Old 08-19-2014
Minnesail's Avatar
I sailed on a boat that used a bungie cord to keep the throttle from slipping back down. Probably not a good long term solution....
Catalina 22
on a starboard tack
Minnesail is offline
post #9 of 14 Old 08-19-2014
nccouple's Avatar
U bolt is a awesome idea. I've been rigging a piece of rope to the throttle when needing more speed. I've received a lot of great tips and tricks just by reading random post here. Hopefully pased a few along also. U bolt is added to my shopping list.
oursailingadventures.com
nccouple is offline
post #10 of 14 Old 08-19-2014
Brian
That looks like what I have.
I figure the idea is that the spring in/on the engine returns the engine to an idle should the throttle cable break. The friction or restriction needs to be close to the control
ggray is offline
Is this throttle position trouble? Ninefingers Boat Review and Purchase Forum 15 12-19-2012 02:59 PM
Just temporary, but it should hold 71Irwin32 Gear & Maintenance 35 01-13-2010 12:55 AM
Hold your course? GreatWhite Racing 64 07-02-2009 11:05 AM
Idle speed and throttle position jaschrumpf Atomic 4 2 06-19-2008 08:56 PM
M-18 - low RPM, Throttle hold John/Illinois Catalina 1 05-19-2006 10:17 PM
