Check Your Chainplates - SailNet Community
 8Likes
post #1 of 17 Old 08-19-2014 Thread Starter
Daniel - Norsea 27
Rhapsody-NS27's Avatar
click on a picture to see a larger view.
While removing my chainplates, I noticed. some pitting and surface rust. They didn't really look TOO bad to me and still felt pretty solid. Then, I was down to two. The bow and the aft chainplate on the port side. The bow took a little time as it was flush with the surface and didn't want to lift up at first. The last chainplate on the side was another story. Each plate for the shrouds have a little block of wood for spacer. The bolts going through them stayed solid in place until I banged them out, but prying the plates from the boat was difficult because the bolts didn't budge. When I went to pull the last chainplate, it gave a little.
I thought it was odd since all the others were pretty sturdy but now I got one with a soft spot. Turns out, there was a hidden crack in it. It was hard to see at first but once I removed the spacer block, I pulled on the plate to exaggerate the bend to show the crack easier. It went right to the bottom of a bolt hole. It ended up leaving one bolt holding the half-shroud that was attached to it.
Can you see the crack?
How about now?
After I pulled a little more, the crack showed up more.
Here, you can see that with were the crack was at the bolt hole, there was only one more bolt before it went to the shroud.
I went ahead and broke it apart altogether to show what was still holding it together. Just the little bit of metal on the left of this picture was all that held it.
The main reason I wanted to share this is to show people why they should check them. I'm sure there's plenty around this forum or other sites online showing damaged chainplates. I wanted to share this to also inform those who are looking for older boats to consider this when shopping around. My chainplates looked ok except for some surface pits, but from seeing other owners of the same type of boat come up with cracks in their chainplates, I decided to do them for preventative measures. Turns out, there was a need for it.
My boat was built in 1981 and these straps of metal are original. If anyone has a doubt about their chainplates or they're just as old as mine are, it might be a good idea to swap them out to ensure that the whole rig doesn't come crashing down.
Happy sailing.
Slayer and christian.hess like this.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is offline
post #2 of 17 Old 08-19-2014
Broad Reachin'
kwaltersmi's Avatar
Re: Check Your Chainplates
Very solid advice and sobering pictures. Thank you!
Catalina 34
kwaltersmi is offline
post #3 of 17 Old 08-19-2014
Previous owner of our vessel experienced a catastrophic mast failure due to crevices corrosion of one chain plate while at sea in calm conditions..However, found through metallurgical examination the SS used was not to boat spec. The Boat manufacturer, after threat of legal action, replaced all standing rigging and mast...
Bottom line check critical pieces often..
christian.hess likes this.
aa3jy is offline
post #4 of 17 Old 08-19-2014
S/V Calypso
clip68's Avatar
Wow! Thank goodness you found that problem "the easy way"!
The average man will bristle if you say his father was dishonest, but he will brag a little if he discovers that his great-grandfather was a pirate. – Bern Williams
clip68 is offline
post #5 of 17 Old 08-19-2014
christian.hess's Avatar
good job man! they parallel my old chainplates to the t
I see 2 cracks btw on you first pic
chainplates and rigging have a lifespan and should be replaced accordingly all too often people think chainplates are born and die with the boat
good pics
and good for you for due dilligence
peace
also fwiw may I offer the advice to change the square carriage bolt hole to a round hole and thru bolt with a standard bolt?
those square "aligning" carriage holes are NOTORIOUS for starting to crack at a mjch earlier date than round holes...
point stress and cracks are easier at hard angles...notice that that hole also has a lot of rust.
cheers
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #6 of 17 Old 08-19-2014 Thread Starter
Daniel - Norsea 27
Good catch on the second crack. I noticed it after I saw the enlarged photos. Smaller, but still there.
I've heard the same about using round holes instead of square ones. Another owner did square with rounded corners that looked pretty good.
I don't know what grade of metal these old chainplates are but I'm going to get new ones made with 316 stainless.
I've also been looking into replacing the bolts since they have some surface rust too. Looking at 316SS bolts, they are expensive and unfortunately, they look like they come in incremental packs, like only packs of 10, so if I need 12 bolts I'd have to get a couple packs (just an example) so I'm looking around at what else I can find. I think 18-8 which is equivalent to 304 stainless may lower costs but might be easier to find too.
Daniel
1981 Nor'sea 27,
-Paul Carvel
post #7 of 17 Old 08-19-2014
As long as you are switching have them made in G5 titanium not stainless. It will cost a little more (seriously just a little), but are immune to corrosion.
davidpm likes this.
Greg
Stumble is online now
post #8 of 17 Old 08-19-2014
snake charmer, cat herder
zeehag's Avatar
i had 2 cracked chainplates when i bought this boat-- and i replaced em for under 200 usd total. fabrication is the key. and i used 304, not 316 stainless, created a tad burlier than the originals that came with this particular boat
formosa 41, cruising tropics
zeehag is offline
post #9 of 17 Old 08-19-2014
recomending 304 on here is akin to saying olive oil is the best engine oil you will get the wrath
If you go 316 go for the L variation.
know this however most stainless sailing hardware is indeed mostly made from 304, and that is because its stronger and cheaper...so more of a money maker, yes it surface rusts easier but again they are intended to be replaced regularly.
ask any stainless davit owner and ask them how brittle their 316 davits are, especially after welding...
look around for tangs, toggles, extenders etc and the overwhelming majority is 304.
sooooooooooooooooooooooooooooo.......
Ill tell you what I did or you can look at my rebuild thread and check them out yourself
I went massive from 1/4 inch to 3/8ths, I extended my stbd plates by 5 hole legnths so it tied to the liner, I also made them wider my ports where also extended
polished to a mirror finish
I used plain old stainless bolts which I forget the grade but more than likely is 304 too
the way I see it you replace these things regularly, a bolt is a bolt not some forever piece of equipment
Id be glad to share some pics if you like
post #10 of 17 Old 08-20-2014
im fabricating new chainplates this fall what material do you recomend 304 or 316L or another spec
the_abuse is offline
Chainplates brokesailor Gear & Maintenance 24 04-08-2012 11:41 AM
Chainplates- are these still o.k.? Hookturn Gear & Maintenance 20 03-15-2012 03:12 PM
Chainplates tager Gear & Maintenance 3 04-17-2009 12:53 PM
My Chainplates simple72 Gear & Maintenance 13 11-11-2006 07:19 PM
chainplates mary jewell Gear & Maintenance 1 10-25-2002 06:10 PM
