Tohatsu 4,5,6 HP Tiller Lock Fix - SailNet Community
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Like Tree1Likes
  • 1 Post By AllThumbs
Old 23 Hours Ago
AllThumbs's Avatar
midlife crisis member
AllThumbs is on a distinguished road
I have made a minor modification to fix the silly tiller lock issue that seems to plague most of the small Tohatsu 4 strokes. (Also Murcury and Nissan)
I created a blog post about it: Tohatsu 6 Tiller Lock Fix
If you run one of these fine outboards on your sailboat or dinghy, have a look.
Eric
GMFL likes this.
I sail.
The Following User Says Thank You to AllThumbs For This Useful Post:
Steve in Idaho (12 Hours Ago)
  #2
Old 20 Hours Ago
dabnis is on a distinguished road
Re: Tohatsu 4,5,6 HP Tiller Lock Fix
Eric
Yes, I have one & it does what you said. It sort of holds a course. Very nice write up on the fix. I may try it when the snow gets deep, if we get any.
Thanks, Paul T
  #3
Old 19 Hours Ago
OPossumTX's Avatar
OPossumTX is on a distinguished road
I have one of the 6HP wonders and it does tend to self steer. It would just keep turning until I ran out of rudder. Very inconvenient if you need to turn the other way!
I handled this problem by putting on an adjustable tiller extension, I bought it off Craig's List for $10 and I shock corded it to the stern pulpit vertical support. This solved two problems. It now doesn't steer itself and I can adjust the throttle without having to hang over the transom.
Now, if I could just get the gear shift extended up so that I don't have to hang half out of the boat to reach the fiddly lever.
Your canvas brake friction band enhancement seems a more elegant solution though. Next time I have it off the boat, I will look at it.
Next is a tachometer/hour meter for service monitoring and so that I can tell when I have reached maximum revs, as if I couldn't tell by ear.
Have FUN!
O'
  #4
Old 19 Hours Ago
chrissailorman's Avatar
A perfect day!
chrissailorman is on a distinguished road
Have FUN!
O'
That's not a hard one to solve....I made an extended shift lever out of a wooden dowel, actually used a sawed off pool cue. Drilled a 1/4" hole, one inch from the end and slipped a 1/4" S&S hex bolt of the appropriate length from behind the shift lever, through the lever and dowel. There's a hole in the center of the shifter handle. Used a few nuts and washers to secure it. It's a little stiff but gets the job done and saves you from a cramped neck!
Chrissailorman
1987 Rhodes 22, Blue Hawaii
Blue Point, N.Y. Great South Bay
  #5
Old 17 Hours Ago
GMFL's Avatar
Large Member
GMFL is on a distinguished road
Cool, thanks for the write up.
I have a 6hp Tohatsu for the dingy but the friction band works fine for now. I'll keep this bookmarked.
thanks again
Tags
6hp , lock , tensioner , tiller , tohatsu
You may post attachments
You may edit your posts
Tiller Lock Squidd General Discussion (sailing related) 23 05-08-2012 10:36 PM
New tiller lock design dfzurcher Gear & Maintenance 19 05-07-2012 11:46 PM
Tohatsu 6: How fix steering position? gallilaw Gear & Maintenance 10 03-30-2011 08:11 AM
Can Anyone Identify My Tiller Lock? GloucesterTom Gear & Maintenance 3 02-06-2011 04:33 PM
Tie up tiller/lock wheel when away? Or not. CalebD General Discussion (sailing related) 23 10-11-2009 05:30 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
