Head's raw water intake not working. - Page 2 - SailNet Community
 5Likes
post #11 of 15 Old 08-19-2014
Re: Head's raw water intake not working.
Originally Posted by christian.hess View Post
its the language thing...on another thread somoen reffered to this as the actual pump diaphragm
my bad then
on the jabsco pumps you want to replace the diagphragm, and spring or else the pump wont action correctly
does that make sense?
sorry for the confusion
I have always wondered why it's called a joker valve
Found this article (It does not explain the name, but worth a read) Joker Valves for Marine Heads - Practical Sailor Article
Edit: Found this
Seems joker valve is the Jabsco adaption of a Duckbill valve
christian.hess likes this.
knuterikt is online now
post #12 of 15 Old 08-19-2014
I think it was originally a choker valve but somebody misspelled it and the sheep followed.
Capt Len is online now
post #13 of 15 Old 08-19-2014
christian.hess's Avatar
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa aaaaaaaaaaaaaaaaaaaaaaaaaahhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
that makes sense
in any case apply video 1 op and see if that is the issue if not apply other vids
sorry for the slight hijack
the reason Im saying this is we just did this on an exact same jabsco head that was left sitting for 4 years
the spring failed and the gasket leaked...
once fixed and inspecting flow of water all was good
works great
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #14 of 15 Old 08-20-2014
Wish I never found SN!
SimonV's Avatar
Had a similar problem. Unscrewed the inlet strainer and it was clean opened the stop valve and water gushed in. It was only when I completely removed the strainer assembly that I found a long length of weed with lots of leaves on it. What was happening was it would compress and plug the line when I stopped pumping it would uncompress and allow water to flow. Do the simple things first and work your way towards the complicated expensive stuff.
Simon
I miss my boat
Brisbane
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #15 of 15 Old 08-20-2014
Superior Sailor
Squidd's Avatar
Thanks for the videos.... I have the parts kit and after watching the video am ready to attack the pump
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is offline
Blocked Raw Water Intake nolesailor Gear & Maintenance 10 02-25-2014 11:44 AM
Raw water intake algee Gear & Maintenance 5 12-13-2013 07:28 PM
Additional raw water intake to supplement saildrive intake. GMC Gear & Maintenance 1 02-18-2012 02:10 PM
Necessary to shut off raw water intake? harpguitar Gear & Maintenance 9 08-09-2008 01:54 PM
raw water intake rchad Gear & Maintenance 12 06-26-2008 08:19 AM
