Jib catches while tacking - SailNet Community
 7Likes
post #1 of 23 Old 08-24-2014 Thread Starter
Fau
Possibly improving
Fau's Avatar
My Jib is ripping as it catches on the ladder that is also the rigging on my sailboat. Is there something that I can attach to the ladder to prevent it from catching?
I've added a picture on page 2. Thanks for looking.
Thanks
Do or do not... There is no try.
Last edited by Fau; 08-25-2014 at 07:11 PM. Reason: Added a picture later in the thread.
Fau is offline
post #2 of 23 Old 08-24-2014
Re: Jib catches while tacking
What 'ladder'? Where is it?
Is it only the sail that's catching or are the sheets catching as well? Obviously tearing the sail on a routine tack is not a good thing, and generally it's easy to avoid. Pictures or more detail will help.
Faster is offline
post #3 of 23 Old 08-24-2014
islander bahama 24
newhaul's Avatar
Please post pictures I'm trying to visualise where on the rigging there is a needed ladder on an O'Day 27
Illegitimus Non Tatum Carborundum.
newhaul is offline
post #4 of 23 Old 08-24-2014
Old as Dirt!
svHyLyte's Avatar
Thanks
Google "Baggywrinkle". Learn how to make it using small stuff from old cast off line and wrap your shrouds with the material, and tightly near/at the ends of the risers. (If you are using solid risers between the shrouds, you would be wise to dispense with them and learn how to seaze "rat-lines" in their stead--Google again).
FWIW...
capta and larrytwo like this.
svHyLyte is offline
post #5 of 23 Old 08-24-2014
Once known as Hartley18
Classic30's Avatar
Dock
Originally Posted by svHyLyte View Post
Google "Baggywrinkle". Learn how to make it using small stuff from old cast off line and wrap your shrouds with the material, and tightly near/at the ends of the risers/rat-lines.
Baggywrinkle is used to prevent chafe.
It will do nothing to prevent lines snagging on rigging (and might even make the problem worse). FWIW..
Classic30 is offline
post #6 of 23 Old 08-24-2014
Old as Dirt!
svHyLyte's Avatar
Ah... Wrong. BTDT got the T-Shirt.
svHyLyte is offline
post #7 of 23 Old 08-24-2014
MarkofSeaLife's Avatar
Dock
Must be the escape ladder.
Yep, we need a photo
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #8 of 23 Old 08-24-2014
Sailor
Gladrags1's Avatar
Mast ladder?
Sent from my iPhone using Tapatalk
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #9 of 23 Old 08-24-2014
I make sawdust
thereefgeek's Avatar
Ratlines (the ladder rungs for climbing the shrouds) ?
A bad bowline with a long tag end will also snag on every tack...
-Rich VanDusen
1977 Tayana 37 Hull #91
Ramble On
thereefgeek is offline
post #10 of 23 Old 08-25-2014
islander bahama 24
newhaul's Avatar
Possible but ratlines on a 27
newhaul is offline
Self-tacking jib heyross Gear & Maintenance 7 06-06-2011 11:04 AM
Self Tacking Jib kgmcgrath MacGregor 7 03-30-2010 09:38 AM
Jib Sheets during Tacking DrB Seamanship & Navigation 8 08-21-2007 01:51 PM
Self-Tacking Jib Conversion jones2r Gear & Maintenance 10 12-02-2006 05:42 PM
self-tacking jib copasetic Gear & Maintenance 3 03-02-2004 06:11 PM
