Hi Seas 100-C diesel heater manual and wick? - SailNet Community
 1Likes
post #1 of 15 Old 08-29-2014 Thread Starter
Greetings all,
Trying to resurrect my old Hi-Seas diesel bulkhead-mount heater. It's in reasonably good condition and I don't want to give up on it quite yet. Found a thread on the subject but it was several years old.
It's a 100-C model. Worked mighty well on my Cheoy Lee way back when. Never did have a manual for it, so if someone has an electronic copy I'd be forever in your debt if you could pass it along.
Also, has anyone come up with an "ideal" available replacement wick, or the easiest one to modify? Must be something out there but if someone has already solved the problem with success I'd surely like to hear about it.
Thanks much
Marcaiche is offline
post #2 of 15 Old 08-29-2014
islander bahama 24
newhaul's Avatar
Re: Hi Seas 100-C diesel heater manual and wick?
I have no experience with the hi seas stove but some experience with house type oil heaters here's an idea that should work or at least some contact info KINDLER WICKING KINDLER WICK FOR OIL BURNING "WICKLESS" STOVES & RANGES
Illegitimus Non Tatum Carborundum.
newhaul is offline
The Following User Says Thank You to newhaul For This Useful Post:
Marcaiche (08-31-2014)
post #3 of 15 Old 08-29-2014
islander bahama 24
newhaul's Avatar
Check with Denise030 she may have some ideas as well
newhaul is offline
post #4 of 15 Old 08-30-2014
One of None
deniseO30's Avatar
I've not been much help on this. but thanks Newhaul for the recommendation
Here's a discussion I was in on. Hi Seas Diesel Heater I guess the guy got it working ok. I has pics
I think you will have make a wick out of a kero heater wick. the valve and fuel supply are always a problem in such gadgets. and "low" is never a good setting.
The wick shop looks like a good source!
My last project!
deniseO30 is offline
The Following User Says Thank You to deniseO30 For This Useful Post:
post #5 of 15 Old 08-30-2014
islander bahama 24
newhaul's Avatar
You worked HVAC on the east coast I'm west coast there is mostly fuel oil here is mostly natural gas I was also thinking on wick for kero heater as well.
newhaul is offline
post #6 of 15 Old 08-30-2014 Thread Starter
Thanks Newhaul and Denise for your help....much appreciated.
Bud at Westsail Parts was kind enough to send a scan of the Hi-Seas manual...absolutely essential, so if someone else needs the info please feel free to contact me and I will pass it along electronically :-).
As far as the wick goes, mine is intact but not in great shape. Conferred with Miles at The Wick Shop about it. I'm going to disassemble the Hi-Seas again, get some pics of the wick and accurate measurements, and send them along to him. He uses the very best materials and it sounds like he can make an excellent, robust replacement vaporizing wick for the 100-C heater...and at a very reasonable cost IMHO. I'll test one to confirm performance and then he'll add them to his inventory list. EXCELLENT NEWS for other Hi-Seas owners!
As far as the metering valve goes, if someone else has one of these heaters and can't get it to work, just about any generic valve can be mounted. As long as the burner isn't completely corroded there's no reason not to return a Hi-Seas heater to service...since it looks like (hopefully) a replacement wick will be available in the near future.
If a person takes the short time to learn how to properly set-up and operate a wick heater they will likely find them preferable to the "pot-burners" currently on the market....simple, safe, and very good performers. Probably lots of these out there in storage because no parts, ie: wicks, were available. I see them go real cheap on craigslist now and then in the pacific northwest.
I need to fabricate a damper for mine and find a charlie noble and associated pipe and caps for the installation but am looking forward to the overnight warmth during winter sailing.
I will post on the new wick and how it performs after installation. As I mentioned, if anyone else has a Hi-Seas give me a shout and I'll be happy to pass along any info I have acquired.
Newhaul: I used to keep my Cheoy Lee at Everett. Split my time on either side of the Cascades now. My little Electra MORC sloop is on the hard in a barn near Sultan at the moment. She'll be back on the water soon. Actually was considering getting on the list for Kingston Marina...seemed like real nice folks the last time I was there as a transient and I liked the idea of stepping off the ferry and right into the marina.
post #7 of 15 Old 08-30-2014
One of None
deniseO30's Avatar
Trouble is all new wicks are made from Fiberglass.. they turn into.. yeah.. glass. the old asbestos was perfect but carcinogenic.
Why not post the manual here so we can all have it? It comes up allot in other forums.
Suggestion.. be ready to use Kerosene it's just cleaner then diesel
My last project!
post #8 of 15 Old 08-31-2014
islander bahama 24
newhaul's Avatar
Actually I my boat is in the bremerton marina with no wait list my lil morc boat what cheoy did you have?
newhaul is offline
post #9 of 15 Old 08-31-2014 Thread Starter
Denise,
Absolutely correct! Actually, I think Miles produces "historically accurate" wicks for antique collectors made out of asbestos, with the obligatory proviso vis-a-vie the legal-eagles concerning health issues. I will ask him about it, although I know the original hi-seas wicks were fiberglass. Asbestos could be the better route of course.
I always use "Jet-A" in my kerosene heaters and lamps whenever possible (I fly). It's highly-refined kerosene with better quality-control...wicks hold up better, less soot and smoke too.
Also...if you live near an aerofield that pumps jet fuel, they are required to "sump" their trucks to check for water, etc. on a daily basis. Often they have a 55 gallon drum somewhere that those sump samples go into that they have to pay to dispose of, and they're more than happy to have an enterprising soul remove it for free... ;-)
I will post the Hi-Seas manual when I get somewhere with a decent web connection. Is there a particular place on Sailnet where it should be posted?
post #10 of 15 Old 08-31-2014 Thread Starter
...oops....one more addendum to the previous post:
Jet-A often can be found with or without "prist" or some other anti-biological additive. Little buggers like to grow in kero-fuel during storage periods, and the additives prevent it. I've never had a problem with wick heaters when using fuel with an anti-biological, but your mileage may vary.
If you can find an FBO at an aerofield willing to give you their sump jet fuel, it will likely be a mix of fuel with and without the anti-biological, and the diluted amount will be too negligible to give a thought to.
'nuff said ;-)
Remotron heater - manual request KBuckley Gear & Maintenance 15 11-09-2016 12:37 PM
Hi Seas Heating Corporation / Diesel Heater MichaelGrant Gear & Maintenance 36 09-06-2015 04:31 PM
Hi-seas diesel heater info wilmit Gear & Maintenance 0 11-29-2012 06:13 AM
Ardic 04D Heater Manual JiffyLube Gear & Maintenance 3 04-27-2011 03:34 PM
Heater wick walt123 Gear & Maintenance 3 06-12-2008 12:06 PM
