05-19-2006
I am not a fan of the suggestion of painting your prop - if it is bronze. If you use just an antifouling you run the risk of creating an electrolosis situation b/c of the metal in the paint. Also, I think you can cause your prop to be less effcient or even unbalanced if the paint is lumpy or not even. I think it is better to dive your prop and scrape it regularly.
Also, I am curious why you think it is your tranny slipping. What other 'symptoms' do you have? Are your RPM's still reaching max?
Susan
LaLeLu 40' Caliber
Merritt Island, FL
