Tiller - SailNet Community
post #1 of 3 Old 07-02-2001 Thread Starter
Tiller
I have a Pearson 28 sailboat built in 1977 and need to fins a tiller that fits with the right lenght, width, and curve. Any ideas ?
JMATTICKS is offline
post #2 of 3 Old 07-02-2001
JeffH
Guest
Posts: n/a
Tiller
Tillers are really easy to make. Typcially they are glued up in mahagany and ashe. On a 28 footer you can make one out of solid mahogany. It is quite easy to rough one out with a jig saw or bandsaw and to shape it with a hand plane. The final trick is to use clamp the end of the tiller in a vice and do a final fairing and shaping by working a sandpaper belt aback and forth diagonally around the tiller. Put some varnish on and you are all done. The whole process takes maybe 16 hours spread out over a couple weeks.
Otherwise there are companies that make prefab tillers. I am drawing a blank on the name of the company that makes them but they are carried by both West Marine and BoatUS.
Good luck
post #3 of 3 Old 07-18-2001
Tiller
Interested in any info/recommendations on a tiller extension for use on a Catalina 27.
southernbreeze is offline
tiller head for a Galilee? TominBC Gear & Maintenance 2 12-01-2012 10:15 PM
Simrad Tiller Pilot jerryr Gear & Maintenance 21 09-25-2008 10:47 PM
tiller maidens? pmills42255 Crew Wanted/Available 2 02-19-2004 07:10 PM
tiller pilot for 38 Ingrid obiec Gear & Maintenance 0 05-10-2003 07:30 AM
Tiller auto pilots newuser Gear & Maintenance 8 01-21-2003 09:21 PM
