winch size? How critical? - SailNet Community
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Like Tree2Likes
Old 2 Weeks Ago
Gregrosine's Avatar
Gregrosine is on a distinguished road
We have a Beneteau 352 and there are only two winches on the boat, both atop the cabin. We have plans to install two additional winches back near the wheel on the combing with a bracket. The winches currently on the boat are Lewmar 42. We have found a good deal on a pair of Lewmar 40. We will use the new winches primarily for the operation of the jib, which is a 140% genoa. The additional winches placed in the back will make single hand sailing much easier.
Will the Lewmar 40's be sufficient or will we have a problem going down one size from the 42's?
  #2
Old 2 Weeks Ago
ASA and PSIA Instructor
Re: winch size? How critical?
I would think you would find the 42's somewhat marginal to start, so definitely don't go down in size. Be sure you have your lead angles worked out carefully and the winches positioned so the sheets can/will fall off the feeder arm or you'll have problems with their operation...
Faster likes this.
  #3
Old 2 Weeks Ago
knuterikt is on a distinguished road
Have you seen this?
http://www.lewmar.com/cms/assets/1/c...tion_guide.pdf
Should not be much difference between 42 and 40..
I have 46 winches (Andersen) on my 38 footer
  #4
Old 2 Weeks Ago
Brent Swain is on a distinguished road
Bigger the better. With so many boats being scrapped, there is a surplus of used winches in excellent condition. I'd prefer a big used winch over a new, too small one.
Brent Swain, Boat designer, Builder, and author of "Origami Metal Boatbuilding"
  #5
Old 2 Weeks Ago
WoobaGooba's Avatar
WoobaGooba is on a distinguished road
I've got 40 equivalent (Barient 23) genoa winches on my masthead 33 footer. They are undersized for a 135 jib when the wind exceeds 15 knots apparent. I'm putting on Andersen 46s this winter.
40s are IMO too small for your jib winches
  #6
Old 2 Weeks Ago
Puddin'_Tain's Avatar
Don't call me a "senior"!
Puddin'_Tain is on a distinguished road
You can always point up and luff the jib a bit if the winch isn't big enough to trim the sail in. Racers want to be able to trim the jib in without luffing, but for recreational sailors/cruisers it's not such a big deal.
Typed on my Underwood Finger-Flight Champion portable typewriter (in triplicate, using carbon paper), sent to my basement laboratory via pneumatic tubes, transcribed by Minions on a Commodore 64 (complete with 5 1/4" single-sided floppy), and uploaded to the Internets via 14.4 kbit/s modem. Ain't modern technology grand?
  #7
Old 2 Weeks Ago
JimsCAL's Avatar
JimsCAL is on a distinguished road
I'm still puzzled by a boat that size with only two winches on top of the cabin.
  #8
Old 2 Weeks Ago
Gregrosine's Avatar
As are we. This is our first boat and you learn what you didn't know after you have sailed a bit.
  #9
Old 2 Weeks Ago
If you find the current winches adequate, why not move them aft and put the 'new' ones on the cabintop for other duties?
Beyond that, I've never heard any sailor say 'Crap.. these winches are too big/strong/powerful'....
killarney_sailor likes this.
  #10
Old 2 Weeks Ago
WoobaGooba's Avatar
This pic explains it ..
OCEANIS 352 (BENETEAU) sailboat specifications and details on sailboatdata.com
You may post attachments
You may edit your posts
Winch size? Gregrosine Gear & Maintenance 8 07-29-2014 07:47 PM
Self Tailing Winch, size ? Question jasper Gear & Maintenance 5 08-25-2009 06:11 AM
Winch handle size? merlin2375 Gear & Maintenance 7 06-11-2008 06:58 PM
Winch handles, all the same size? zz4gta Learning to Sail 5 11-27-2007 09:17 PM
winch size maestro Gear & Maintenance 6 12-19-2002 08:09 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
