Mcgreggor questions - SailNet Community
 8Likes
post #1 of 11 Old 09-02-2014 Thread Starter
davidpm's Avatar
Mcgreggor questions
Last Sat I took a new boater out on his Mcgreggor. The first four hours were just rigging the boat. I've never had any experience with this boat before. It is supposed to be the older model, maybe an X not the newer M, if I got that right.
50 HP motor, water ballast, roller furling jib.
So for those of you who know the boat I have a bunch of questions. The last two owners were not sailors so I'm pretty sure a lot of things were not setup to factory specs.
To raise the main their are two very short stays maybe 4' long in line with the tabernacle. Do they typically stay rigged while sailing or only used for raising the mast?
The line to the block and pulley system to raise the mast was connected quite low right on top of the cleats. I'm thinking it would work a little easier if it was put just above the baby stays. Is that right?
There was no sail stop to prevent the slugs from falling out of the slot. I rigged a short line between the two cleats on the mast to fix this. What is the factory solution?
Adjusting the tension o the stays was tricky at best. The boat has crimped rigging rather than swaged shackles. Is that standard.
He had no main halyard so we used a piece of maybe 5/16" three strand that stretched so much as to be almost useless. What is the typically halyard. I use VPC for real boats but maybe that is overkill for this.
The jib sheet seems to route to a block on a short track on the cabin roof. I routed the sheets outside of the life lines but they seemed to interfere. We had a lot of wind so we had the jib partially rolled up so it may pull fair when unrolled properly.
Anything else I should know about this boat?
We really had too much wind and were playing doge ball with the ferry and boats waiting for the bridge so we only played with it for an hour.
He had a great time anyway but I'm hoping I can give him a better experience with lighter wind and my knowing the boat a little better.
I found an on-line pdf manual but it didn't answer many of my questions.
davidpm is offline
post #2 of 11 Old 09-04-2014
El Chupa Nibre
Mr. Bubs's Avatar
Re: Mcgreggor questions
Dang. It should take about 20 minutes, maybe 30 if you're single-handing.
They should be longer, but only rigged whilst raising the mast.
Yes, it should be much higher on the mast to facilitate raising it.
A sail stop. I keep several on board as they are inexpensive and tend to wander into the drink quite often.
Crimped rigging is standard. Other than the forestay, the rigging should be "set it and forget it". The shrouds and backstay should always remain connected whether the mast is raised or down, although you should check the tension whenever it's raised.
5/16" double braid polyester rope is standard I believe.
Jib sheets should be routed outside of the lifelines, but I'm not sure specifically how it's set up on that particular model.
davidpm likes this.
Mr. Bubs is offline
post #3 of 11 Old 09-04-2014
Azzarac's Avatar
If she were equipped with a 50 hp, my guess was she's an X. You can tell the difference at a glance between the X and M with the black bandit stripe. The X has a single stripe where the M has two. I agree almost entirely with Bub except that I leave the "baby" stays attached once the mast is raised. It keeps them from getting lost or in the way and they are always at the ready when needed. Mine are 3-4 ft long also. DO NOT attempt to use the mast raising system without them in place! The gin pole of the mast raising system (MRS) should be approximately 45-50 degrees from the mast and attached to your jib halyard. The MRS line should be attached to the padeye right behind the forestay.
I just replaced most of the halyards on Chameleon but can't for the life of me remember what size they were. They definitely should not be "stretchy".
The rigging should be swaged with a Nico press. If it were hand crimped I wouldn't use it. IMO it just wouldn't handle the loads required of it.
For more info on these unique boats you can visit Chameleon's site at: SVChameleon - Home or for more in depth info: MacGregorSailors.com
Hope this sheds some light on your questions!
davidpm and christian.hess like this.
“If you surrender to the wind, you can ride it.” – Toni Morrison
"Sic gorgiamus allos subjectatos nunc"
Follow Chameleon's travels at:
Azzarac is offline
post #4 of 11 Old 09-04-2014
El Chupa Nibre
Mr. Bubs's Avatar
Azzarac where are you located? I think we're fairly close.
Mr. Bubs is offline
post #5 of 11 Old 09-04-2014
Azzarac's Avatar
Oh, hey Mr Bubs. I didn't see your location before. We are just outside of Kansas City so yeah, not too far away. I bet you have fun with all those big lakes in your area!
Mr. Bubs likes this.
Azzarac is offline
post #6 of 11 Old 09-04-2014
El Chupa Nibre
Mr. Bubs's Avatar
Yeah, we do! Do you get to Stockton often? I saw it mentioned on your blog.
Mr. Bubs is offline
post #7 of 11 Old 09-04-2014 Thread Starter
davidpm's Avatar
Thanks you all.
davidpm is offline
post #8 of 11 Old 09-05-2014
mitiempo's Avatar
Yes, you can water ski behind it!
Brian
mitiempo is offline
post #9 of 11 Old 09-16-2014
06HarleyUltra's Avatar
In addition to Mr Bubs,
Low speed handling can be tricky, until you find the knack. When motoring around 0-7 mph, I have both rudders in the water to help with maneuvering. I also keep the board down a couple of feet. Any speed above this, pull the rudders up, as you can break them. I also keep the board down for low/moderate speeds on the motor. Anything above 10-12 and I pull it up. You can take on ballast for extra stability when motoring, but I find this unnecessary. Always take on full ballast for sailing!!
A loos gauge is used for proper tensioning of the rig. Their inexpensive and will optimize your rig. It's well known that it's not the greatest sailing boat in the world, so understand and optimize as best you can for the best results.
We love our Mac for lake sailing and motoring about.
Rich
06HarleyUltra is offline
post #10 of 11 Old 09-16-2014
I bought a 2002 26X after keeping a traditional trailer sailor for a few years. It's a great boat for a family on a budget that wants to do a lot of different things...sailing included.
We've loved it and my family and I have spent more time in the water in the last year than we spent combined in the previous 3.
However, a lot of non-sailorly types do buy and use these things as cabin cruisers and I've helped other new (to them) owners with similar issues you describe.
. The first four hours were just rigging the boat. I've never had any experience with this boat before. It is supposed to be the older model, maybe an X not the newer M, if I got that right..
It should take an HOUR tops for the first time, most people can get it down to 15-30 minutes. Check for the black stripe, if it has 2, it's an M.
Those are there to support the mast while you're raising it, they don't have to be in place once the mast is secured, but unless you're planning to go forward a lot, I'd leave them in place just because it's a pain to secure them elsewhere.
The mast raising system should attach to a harness on the mast and to the forward cleat. A gin pole helps keep the angle shallow enough. I reccomend getting a johnson lever at the front. That way you can use the mechanical advantage to tighten up the forestay.
There was no sail stop to prevent the slugs from falling out of the slot. I rigged a short line between the two cleats on the mast to fix this. What is the factory solution??
A slug stop...I'm not sure what the part is called, but it sldes in the bottom of the track and tumbscrew secures it in place. I've had a version on every sailboat I've owned/sailed
Yes, but with the exception of the forestay when raising/lowering the mast, you don't have to adjust the stay tensions. Just check them periodically.
Yeah, he needs to get some new lines. I believe the factory provides a 5/16 cotton/nylon blend braided line. The sails are fairly light so it doesn't have to be overkill.
I run the jib sheets inside the lifelines to jib cars then to the winches/cams on the cabin top. I run the sheets for my Genoa/Spinnaker (when I fly them) outside the lifelines to blocks on the cockpit gunwale to the winches/cams on the cabin top.
Keep part of the keel/daggerboard down (4-6 inches) when motoring, it helps with tracking and low speed control. When docking or in close quarters, drop a rudder, it really helps but raise it before you go over 5-6 mph to keep from damaging them.
As for sailing, the X doesn't point as well as I'd like and can be frustrating, but the M didn't seem to have that problem. The X also tend to round up when overpowered which can be a good thing for a beginner.
My advice while the owner is learning to sail, keep the motor down for awhile, not only does it take the wieght on of the steering mechanism, the engine is already in place for when stupid beginner mistakes happen (and oh how they happen)
Check out MacGregorSailors.com, it's an active community with a lot of knowledge and some very innovative/knowledgeable enthusiasts.
davidpm and Mr. Bubs like this.
SENCMac26x is offline
The Following User Says Thank You to SENCMac26x For This Useful Post:
davidpm (09-16-2014)
Some questions Christian Winkler Announcements and Suggestions Box 0 07-22-2011 01:03 AM
Many Questions Gorlog Gear & Maintenance 8 11-25-2008 11:44 AM
questions OPTIMANIA General Discussion (sailing related) 23 12-26-2007 12:32 PM
About To Do It Questions Jack7 Living Aboard 18 02-26-2004 10:31 AM
Many questions rlockard Living Aboard 9 10-14-2003 04:09 AM
