Stuck Wires - SailNet Community
post #1 of 3 Old 05-21-2006 Thread Starter
Stuck Wires
I am in the process of rewiring my newly aquired '68 Morgan 34, and have a hit a snag. Where wires go up through the bulkhead channels, to all the bulkhead lights (V-berth, Quarters, Galley, and Head), they seem to be stuck in, perhaps glued in when the decorative panels were glued to the bulkheads. Is there a way, short of removing/cutting the panels, to get these wires unstuck, or has anyone run into a similar issue and found a way around it? Any input would be very helpful. Thank you.
68morgan34 is offline
post #2 of 3 Old 05-21-2006
Sasha_V's Avatar
It is a real problem, and a very common one. If the wires are corroded because they were never fully tinned wires, the cores just pull apart and you get left holding a short length of nothing much.
I managed to get around the problem in most areas by running new woring in specific conduits that we installed and deliberately made accessible for future work. It can be made to look attractive, or at least like it belongs.
For the couple of areas where I HAD to follow the old wiring path, I fabricated a tool that was based on something plumbers use to bore out tree roots from pipes.
I used an old cable halyard and crimped on a short lenght of tube at one end so that the tub projected empty for a little way. I then inserted a drill bit that I had machined down the rear of (An 8mm one) so that it fitted into the "socket" of the tube at the end of the cable. A nice flat spot weld to hold it in place and another tube crimped over the other end of the vable (the cable should not be too long, and you should always have the room to run it pretty much straight even when you start the hole.
Use a cordless drill nd a helper to support the middle sections. Dig as much of a pilot tunner in the stuck together conduit as you can with a screwdriver or icepick, insert the drill end and slowly start boring your way through the old wires and insulation. Pulling the whole cable out frequently to clear the debris.
It can go around some fairly noticeable bends, and you always know how deep you have gone by being able to mark the cable and pull it out and lay it along the run to see when you have cleared obstacles andsuch.
A bit of a slow process, but kind of elegant in its solution.
When you have finished, unhook the drill end, tape a really strong messenger line to the cable and pull all the way through. This can either guide your new wires, or iff the hole is too narrow, then you can attach various rasp-like things to further increase the size of the hole. It should even be possible to switch up to a larger sized drill bit and repeat the process now that you have a pilot hole...but we did not need to, so I can only presume that would work.
This is definately a team job, one person ends up sitting in a mess of twisted halayrd cable!
Your helper should be wearing nice sturdy gloves, and preferably eye protection, just in case the cable goes "sproing!".
Sasha
Sasha_V is offline
post #3 of 3 Old 05-22-2006 Thread Starter
Stuck Wires
Thanks, I shall have to give that a try.
Coast Guard rescues two after boat gets stuck (Asbury Park Press) NewsReader News Feeds 0 05-13-2006 05:15 AM
Stuck Keel spaulhk Gear & Maintenance 3 05-03-2006 09:39 AM
Man, dog rescued from sailboat stuck off Va. Beach - WVEC.com (subscription) NewsReader News Feeds 0 04-26-2006 06:15 PM
STUCK SOMEWHERE & CAN''T FIND CREW? I''M AVAILABLE & piclarke Crew Wanted/Available 1 04-12-2003 12:49 AM
Stuck somewhere and can''t find crew. piclarke Crew Wanted/Available 3 10-23-2002 08:17 AM
