-   -   Restoring non skid decks (http://www.sailnet.com/forums/gear-maintenance/16466-restoring-non-skid-decks.html)
Petar 05-24-2006 01:24 AM
Hi,
I have a 27 years old Dufour 31 sailboat that needs restoring non skid decks as gelcoat on it is pretty tired/oxidised and chalky. Smooth vertical surfaces in the cokpit are easily restored with cutting compound/polisher using variable speed orbital sander with cloth. After that applying wax brings back the shine and good looks.
I believe it could be used on decks as well but I am afraid that cutting compound (without subsequent waxing) will make the decks too slippery and dangeorour to wakl on.
Does anyone have an idea as to how to restore the non skid decks surfaces without making it too slippery in the process.
I would appreciate some ideas / suggestions.
regards
Petar
sailingdog 05-24-2006 06:55 AM
generally non-skid needs to be "restored" by painting with a good non-skid paint.
sailandoar 05-24-2006 08:37 PM
Gelcoat / Spheres / Sand / Salt / Treadmaster
(1) There are people that do actual restoration of gelcoat non-skid but I can;t tell you who to call or give you any idea of price.
(2) Non-skid in paint is a good solution.
(a) plastic spheres in paint: work well, don't hold/trap dirt, Gentle on clothes/skin
(b) sand in paint: best traction, holds dirt, can draw blood/rip clothes
(c) course salt sprinkeled on wet paint (hard epoxy) - dissolves out with water rinse: great traction, can be very/too sharp
(3) Treadmaster
Note the spheres are sold by interlux, it is not real agressive but it works well and is my favorite. We have old treadmaster that is painted over with one part modern marine paint with the spheres mixed in before brushing. have been using the spheres for about 10 years and like it/them.
Faster 05-24-2006 11:28 PM
Awlgrip also sells rubber bits (griptex, I believe its called) to add to the paint. We used a mix of grits - they make it in several sizes - and sprayed it on. It made for a smooth, uniform attractive finish, though not the best nonskid, especially immediately after painting. The first season was a bit slippery, but it did wear in and get better.
Using sand can work, but use good white sand or it will get ugly when you eventually wear through the paint.
Have also seen a very aggressive non skid developed with thickened gel coat rolled on. The roller " pulls" the thickened mix into peaks as the nap rolls off the surface. In one case it was so aggressive that it required sanding and repainting to make it easier on the knees and bare feet. However nobody ever slippped on the surface!
It's always a bit of a compromise between effectiveness, appearance, and ease of application.
The glue down "Treadmaster" style is probably one of the best, but costly and the dark colours can get very hot underfoot in the summer heat (as can darker coloured contrasting non skid paint) When we painted as described above we took a medium grey deck and painted it white because in summer bare feet on the grey was like walking on hot sand.
vindauga 05-27-2006 09:31 AM
I have been using Meguires on the non-skid of my Ericson 27 for several years with very good results. I use the oxidation remover followed by the polish. I apply the two compounds with a buffer and then remove the dried material with a cloth. I then use a scub brush to remove the remaining dried material from the small crevasses in the non-skid. I do not use the wax in order to avoid a slick deck.
LDH 05-30-2006 08:05 PM
I'm considering using Durabak or Tough Coat. The Durabak sounds like it will wear well but I haven't heard how well Tough Coat holds up.
Bob T 06-11-2006 05:34 PM
You can make your own non-skid using Imron urethane paint. Carefully mask the area where you want traction. Masking tape must bind very well to substrate otherwise Imron will wick under tape. Using foam West System rollers, roll on one coat of Imron. Immediatel roll on a second coat of Imron, then immediately roll on a 3rd coat of Imron being careful to get a very smooth, even application of the paint, and right behind the roller on the 3rd coat sprinkle sugar very smoothly and evenly. You can strip off the masking tape about 1 hour after the sugar is applied. Let textured area stand about 16 hours then rinse off sugar with a water hose using fresh water. It will leave a durable non-skid textured surface.
You might want to practice in a non-public area before trying it out on the deck where everyone can see the results. I can't ephasize enough, the masking tape must be tight to the substrate, the third coat of paint must be very even, and the sugar must come right behind the roller on the 3rd coat. The sugar must be applied very evenly. It's really easy to do, but you must be focused.
Be careful to apply the sugar in a nice even smooth application. I like to use a salt or spice shaker. The pattern you create with the sugar is what you will see after the sugar is washed off. Let dry and harden for about 3 days before giving it heavy use. If the texture is too harsh, you can sand lightly to ease it. Imron is one of the few paints which is tough enough and doesn't tend to "yellow" over time.
FrankLanger 06-12-2006 02:23 PM
Questions for BobT
When you say "immediately" roll on the 2nd and 3rd coats, do you mean even before it dries, or paint/let it dry and then next coat paint/dry and finally the 3rd coat paint/dry followed immediately by the sugar before the paint dries? Also, how do you sprinkle the sugar on the wet paint, keep a "wet edge" and not step in the fresh paint--it sounds like quite a logistical nightmare. Any comments?
Frank.
Bob T 06-13-2006 12:15 AM
Just as soon as you get to the end of the first roll-out, you immediately go right over it with the second coat, and then the third. Do not wait. Try to work in small areas. 8" behind the rolling of the 3rd coat, you sprinkle the sugar. What you're trying to achieve is a thick wet batch of paint which will wrap around the sugar crystals. If it's too thin or allowed to dry even a bit, the surface will develop a skin and it will not wrap around the sugar and you will get a thin blotchy texture. This texture technique is best done with a helper.
As for logistics, I'm assuming the the original fiberglass has patches of texture with smooth perimeter borders. If it were me, I'd roll or spray on a two coat covering over the original gel coat, trying to achieve a smooth even look, then when the base paint was dry, I would go back and mask off the areas where I wanted good texture or where the original texture shows thru the Imron and do the Imron texture technique in those areas. The texture can be masked to create patterns such as grids, checkerboards, strips, dots, accents, diagonals, or whatever. You could use 1/4" fineline masking tape and make a grid where the original texture was and the end result would be a handsome texture grid over the original. The Imron produces a durable somewhat aggressive texture. It is definitely not going to be slippery. The texture I have on my windsurfing board has been on there nearly 7 years and it is in almost as good of condition as when it was new, and this is a board I sail maybe 50 times a year. Just as important, the Imron has not yellowed. It is very near the same color as new.
hellosailor 06-13-2006 04:23 PM
The folks at West/Gougeon suggest troweling on a thickened epoxy using a notched trowel so you have a known and constant amount of material, and then rolling it with a roller to knock it down making it similar to a stucco finish, with non-skid granules in it. I think I'd be more partial to just gluing on Treadmaster though, because so many non-skid surfaces can really wear a hole in foulies and flesh, and the application is so much simpler, gluing down rubber sheets instead of experimenting with "stuff" that you don't know the final result of, unless you start experimenting on scrap plywood.
