Marina Electrical Problems - SailNet Community
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Like Tree5Likes
Old 09-09-2014
last mango is on a distinguished road
The marina which is also our home seems to have above normal electrical problems with their power boxes we connect to. Over the summer a couple of the power boxes have caught fire or over heated to the point of melting the box connections or cords on several boats. Last week one owner just happened to be on his and looked up and saw the box smoking and pulled his cord to find the connector burned and melted on the power cord. Today another boat had the issue where it burned on both ends of the power cord. The marina blames the boats saying they are overloading the cords. The breakers on the dock or boats are not blowing which is the worry. Can see several dock boxes burned. Looking for thoughts on how we decide if this is a marina issue or a boat issue as quite a few have had this issue off and on. Know my boat I'm conscious of not running the AC with hot water heater, microwaves, ladies with the hair dryers and such together. Not sure how to check to see if the dock box is adequate for what it supplies or more fault from the boats. Stayed at other marinas and never saw this many issues. Any thoughts appreciated
thanks
Another Day
Endeavour 38
Mobile, AL
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 09-10-2014
bgeddes's Avatar
bgeddes is on a distinguished road
Re: Marina Electrical Problems
Loose connections or dissimilar metals not properly treated. Corrosion of the connections is another possibility. Doubtful a marina wide load issue, more likely a connection unable to handle the loads.
  #3
Old 09-10-2014
desert rat is on a distinguished road
how about a temperature sensor at the connector ends?
Zen is a matter of recognizing reality.
  #4
Old 09-10-2014
Classic30's Avatar
Once known as Hartley18
Classic30 will become famous soon enough Classic30 will become famous soon enough
thanks
What brand/model power boxes are the marina using? Or are they custom jobs? How old are they (ie. when was the marina built)? Do you have a photo of a burnt one??
  1. It's quite possible it's a loose connection/corrosion issue... but I'd expect that if only one failed - not a few of them, unless
  2. If they're custom-made, they could contain either poor quality electrical gear or gear that is not marine-rated and thus shouldn't be there in the first place.
  3. It could also be a design issue: The people who did the power distribution system design didn't make adequate allowance for earth fault or phase imbalance, meaning high currents in dockside cables and connections that aren't designed for it.
It's highly unlikely to be a 'boat' issue.. it sounds like more of a 'many boats connected at once' (marina) issue to me.
"Honestly, I don't know why seamen persist in getting wrecked in some of the outlandish places they do, when they can do it in a nice place like Fiji." -- John Caldwell, "Desperate Voyage"
  #5
Old 09-10-2014
SVAuspicious's Avatar
Mermaid Hunter
SVAuspicious will become famous soon enough
A little of this and a little of that most likely.
The 30A twist lock connectors leave a great deal to be desired, especially as oxidation builds up. Oxidation increases resistance which increases heat which leads to scorching of the connectors. This is a very frequent problem with boats that run their A/C a lot.
Add to that the possibility of loose connections inside the power pole and the heat can get rather high, all without blowing any breakers.
As noted above the power distribution systems in many marinas aren't all they could be. Most are wired by electricians who don't frequently deal with the corrosive environment, large temperature swings, and high vibration environment of a marina. Look for signs of overheating inside the power pole. Terminations should be in accordance with NFPA guidelines for marinas.
Boaters don't help. "Hot-plugging" cord sets is tough on them. Breakers on the power pole should be off while plugging in and turned on only after everything is connected. Those spiffy cord covers trap heat in the cord which isn't good.
Marinco advises: "Look for signs of corrosion or overheating. Examine ends of cord set, face of inlet on boat, and receptacle on dock. Look for corrosion, discoloration or melting. If evidence of corrosion or overheating is present, DO NOT USE AFFECTED ITEM. Replace item or seek qualified help."
I suggest reaching out to the marina management in a collaborative fashion and try to get everything - infrastructure, procedures, inspections, and usage - improved.
sail fast and eat well, dave
S/V Auspicious
AuspiciousWorks.com
beware "cut and paste" sailors.
  #6
Old 09-10-2014
JimMcGee's Avatar
JimMcGee is on a distinguished road
The marina which is also our home seems to have above normal electrical problems with their power boxes we connect to. Over the summer a couple of the power boxes have caught fire or over heated to the point of melting the box connections or cords on several boats...
...The marina blames the boats...
We had similar problems at our marina after hurricane Sandy submerged the whole marina for several days.
Same thing, the marina blamed the boats, didn't want to spend the money.
Let me ask you this, have you ever seen a fiberglass boat burn? Now imagine trying to get out of your boat, your home, at 4AM while its on fire and burning with the ferocity of a fiberglass fire.
That's the image that kept going through my mind. That's why we moved. It's hard changing marinas. You get attached, you have friends. Now re-read the previous paragraph and decide if it's worth staying. Online threads speculating long distance on what might be the problem are a waste of time.
If you're living in a fire trap common sense says get the hell out.
And if the owners had any shred of moral responsibility there would have been an electrician looking at the problem after the first electrical fire. Their actions tell you everything you need to know.
L124C likes this.
95 Catalina 30 Island Time
ďThe sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
  #7
Old 09-10-2014
ehmanta's Avatar
Sailing Junkie
ehmanta is on a distinguished road
I'll second what Jim just stated.....get out before disaster strikes. We had a huge marina fire nearby at Colonial Beach, something like 70 boats were lost. Once these fires start, there's not much to stop them, they burn fast and spread fast because of the fuel and fiberglass.
If you're in Alabama, has the marina piers ever been underwater because of a hurricane or other? Salt water will wreak havoc on the electric pedestals.
"Tortuga's Lie"
Tartan 37-C, #59
  #8
Old 09-10-2014
Maine Sail's Avatar
thanks
Sadly this has more to do with the piss poor wiring standard we use in the US for shore power. Owners DO often overload these plugs/sockets and the reality is that once they are beyond new pushing most 30A services to more than 20A - 24A can result in tremendous amounts of heat and potential fires. Corrosion and poor plug socket design both lead to high resistance. There could also be corrosion in the pedestal connections. The voltage issue needs to be addressed but it could be caused by corrosion, undersized wire feeds or simply worn out sockets etc.
Circuit breakers trip on 'overload" but you CAN start a fire at well below "overload" due to high resistance.
Smart Plug vs. 1938 (LINK)
______
-Maine Sail / CS-36T
  #9
Old 09-10-2014
ccriders is on a distinguished road
As above, if the circuit breakers are not tripping and you are getting fires and charred connectors, it is not a amperage problem, but a resistance problem. I can't imagine a marina not addressing the problem immediately as the danger is very high. I like the idea posed above about a cooperative system analysis to ensure all elements are to standard, power mains, panels, switches, connectors, cables, users procedures, etc.
I recently moved to a new slip and found that the connector on the panel was charred. I walked over to the marina office and told them about it. That afternoon an electrician was there, diagnosed the problem and told me it would be fixed the next day. He then Put a big red and yellow danger sign on the panel and disconnected the other power cord. Now this is a city marina and they normally don't jump right on reported problems, unless they are a fire or safety hazard.
Also, if you are on 30 amp service and are running an air conditioner and a water heater, then when the refrigerator kicks on you will probably be over amped and should be tripping circuit breakers. Add up your loads especially cyclic startup loads that are not switch controlled, with more than one in startup you could easily be overloading. If that is the case, find out why the breakers are not tripping.
John
  #10
Old 09-10-2014
MarkSF is on a distinguished road
I was lucky to be on the boat when the shore power connector at the boat end melted down. It was a very rainy day, which I do not think is a coincidence! It would not come as a surprise that the same thing can happen at the dock end.
As others have said, the problem is older connectors with a buildup of oxidation. Add damp conditions to the mix, and bob's your uncle.
You may post attachments
You may edit your posts
Solving Difficult Electrical Problems Prescinding Electrical Systems 9 11-26-2011 09:29 PM
1976 P30 Mast Electrical Problems Uberbigun P30 1 05-28-2009 02:11 PM
Marina Problems OhioSailor General Discussion (sailing related) 22 05-13-2008 09:33 AM
Major Problems With Marina hamiam General Discussion (sailing related) 33 11-28-2007 04:33 PM
electrical circuit problems petergumbrell Gear & Maintenance 7 10-01-2007 11:57 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
