Old 05-24-2006
tijel is on a distinguished road
Tankless propane hot water
We are considering installing a Showermate (tm) tankless propane hot water heater made by Precisiontemp Co. in our 35' sloop. Does anyone have any feedback on these things? Performance? Ease of installation? Drawbacks? Any insight appreciated.
Old 05-24-2006
hamiam is on a distinguished road
tankless
these tankless heaters have been discussed in the past if you do a search and/or google it. Other than the expense, it sounds like a great idea. Who wants to run their engine in the middle of summer to heat water?
Old 05-24-2006
Check insurer
These types of heaters do make basic sense, and there are a variety of makes available. One point, we looked at a boat once where such a heater had been removed - not because it didn't work, but because that particular owner's insurers wouldn't cover the boat with that (propane fired) heater - so do some checking about that before you buy.
They often take up room in the head area, usually cramped to start with, but depending on the boat you may find a good fit for one.
Old 05-24-2006
One problem with the tankless water heaters. They're not very effective if the ambient temperature of the water is relatively high. The heat transfer is far less effective if the water is relatively warm to begin with, so it may not work as well as you'd like in the summer.
This is especially true if you live in a warmer climate... if you sail in New England, or the Great Lakes it might work acceptably...
Old 05-24-2006
captlar's Avatar
can't re Member
captlar is on a distinguished road
Here in the States the issue is insurance and finance companies will not approve instant heaters unless you can vent them directly out of the boat. We had an old Paloma and looked at keeping or upgrading. I could not find a unit that was small enough to fit in the head and I could not find a reasonable way to vent out. Smaller units are not made to vent out. Units made to vent out were huge. All manufacturers I found specifically stated the unit was not to be used in any confined space including boats and campers. Seems like too many "no" answers, so we put in a new isotemp. We have to run the engine to get in and out of the marina and we carry a couple of sunshowers so one way or the other we will have hot (enough) water.
Larry
Old 05-24-2006
Omatako's Avatar
Omatako will become famous soon enough
I had a small Junkers quick-heater in my boat that could only be used with the forehatch open to vent the heat from the burners. Couldn't be used in anything but tranquil conditions and used mountains of gas. And nobody could step over the hatch while this thing was running!!
Now I run a small 35 litre hot water cylinder off the engine. Diesel is in any case a lot more readily available than gas and is also less expensive. The right heaters get hot really quickly and stay warm for several hours.
I would never have another gas quick-heater.
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
MacGregor 26 vs. ? jiml2p Boat Review and Purchase Forum 184 08-30-2011 08:10 PM
Who is Killing Our Water Access lowryjim General Discussion (sailing related) 14 07-18-2007 06:16 PM
Protect Your Right to Water Access lowryjim Living Aboard 0 11-28-2005 08:30 AM
On demand propane hot water heaters pjfsail Cruising & Liveaboard Forum 8 07-01-2005 02:47 PM
