Treadmaster - SailNet Community
post #1 of 3 Old 05-24-2006 Thread Starter
Treadmaster
We have a steel deck and are replacing the non-skid with TreadMaster. After we grind and primer, do we need to paint before applying the epoxy? Thanks
bduning is offline
post #2 of 3 Old 05-25-2006
sailandoar's Avatar
We have tread master on steel deck 10yrs old and it was put on top of a normal epoxy coating system. What were you thinking of instead? The only place I can think of that you might shortcut is, that some of the epoxy coatings are not recommended as topcoats but should be shielded by a topcoat/color-coat, and the treadmaster will serve that purpose.
sailandoar is offline
post #3 of 3 Old 06-01-2006 Thread Starter
To clarify, my question is about what goes under the epoxy. If I grind down to metal, then apply a primer, can the epoxy & treadmaster be applied on top of that, or should the primed surface be painted first? Thanks
bduning is offline
Restoring non skid decks Petar Gear & Maintenance 9 06-13-2006 04:23 PM
treadmaster mary jewell Gear & Maintenance 0 05-04-2004 08:58 PM
replacing deck non-skid gto2 Gear & Maintenance 4 08-22-2002 03:47 PM
Treadmaster removal joseph53p Gear & Maintenance 1 11-16-2001 12:49 PM
