New seals for Ports / portholes - SailNet Community
Blogs
Old 05-25-2006
D.H. Anderson is on a distinguished road
Several of my Lewmar ports on my 1997 Beneteau 36 CC are now leaking rain water and while the gasket material on each of these doesn't appear to be in bad shape, I obviously need to replace it. Can't seem to find anything from Lewmar to use for this purpose (it would be over-priced anyway!). Does anyone have any suggestions for where to get this gasket material?
D H Anderson
Old 05-25-2006
Neoprene can be used in a lot of different ports. You might want to try getting some sheets of neoprene and cutting gaskets from it for the ports.
Old 05-25-2006
It may be worth your while to actually contact Lewmar directly with this problem... Friends had trouble with the Lewmar hatches on their Beneteau and Lewmar was quite helpful in addressing the issue (actually replacing some of them free of charge). Granted yours is an older vessel, but it won't cost you much to try.
Old 05-25-2006
Good point... some companies are better about standing behind their products, even if they are older ones, than others are. I don't know how Lewmar is, but I hope that they're one of the better ones, as I have a fair amount of Lewmar gear on my boat.
Old 05-25-2006
r1mannion is on a distinguished road
To: all
Re: I am looking for water deck fill caps for endeavour 38. The standard caps
for sale don't have the proper threads for my boat. Any one know where I can find proper caps?
Old 05-25-2006
Originally Posted by r1mannion
To: all
You really need to start a new thread instead of hi-jacking the OP's thread, which is un-related for two reasons. The first is that it is just proper net etiquette. Second, you'll probably get far more appropriate responses to your question in its own thread.
Old 05-26-2006
Unhappy
sorry sailingdog senior member
this was my first attempt to start a thread. I appologize for any irritation it may have caused you.
thanks, r1mannion
Postcard from Outer Brewster: Save the Date and See the Seals! NewsReader Mass Bay Sailors 0 04-10-2006 01:15 PM
Leaking portholes dsprygada Gear & Maintenance 1 01-31-2005 06:31 PM
Experience with Dripless Shaft Seals hamiam Gear & Maintenance 10 02-19-2002 09:24 PM
Seal''s Spars & Rigging risco Gear & Maintenance 0 11-07-2001 09:30 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
