Paint for Cabin - SailNet Community
 13Likes
post #1 of 32 Old 09-25-2014 Thread Starter
Transplanted Yankee
Paint for Cabin
What sort of paint should I use inside the hull, down below in the main cabin on an old wooden boat that has been prepped with Smith's Clear Penetrating Epoxy Sealer?
shisaisama is offline
post #2 of 32 Old 09-25-2014
Re: Paint for Cabin
Probably any good paint would stick well over that, but you might want to check with Smith's and the paint company before using any particular product, in case either of them has had issues.
I would expect any good white enamel paint to do, followed in price and durability by bilge paint, urethane paint, and epoxy paint. For non-commercial use, plain white enamel paint probably will do. And since it is a boat, you might add a packet of mildew preventive into it as well. (Again, check with both makers for compatibility issues.)
hellosailor is offline
The Following User Says Thank You to hellosailor For This Useful Post:
shisaisama (09-25-2014)
post #3 of 32 Old 09-25-2014
pdqaltair's Avatar
Re: Paint for Cabin
I'd go further and say any interior semigloss, though I would opt for a better brand (Bejamin Moore for ex.).
I did a cabin on one boat, and the lockers in another. There's not much point in going with a topsides paint unless you do the glass finish surface prep that goes with it.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
The Following User Says Thank You to pdqaltair For This Useful Post:
post #4 of 32 Old 09-25-2014
tommays's Avatar
Re: Paint for Cabin
Valspar exterior at lowes
It just passed the four year test
shisaisama and Rhapsody-NS27 like this.
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
The Following User Says Thank You to tommays For This Useful Post:
post #5 of 32 Old 09-25-2014
Re: Paint for Cabin
Benjamin Moore has become such a coveted name, that they've reported problems with painters re-using empty cans, filling them with other products, and claiming they are using Benj.M. paint on jobs when they aren't. Go figure, paint is so expensive it is worth "counterfeiting" now.
post #6 of 32 Old 09-25-2014 Thread Starter
Transplanted Yankee
Re: Paint for Cabin
Thanks, guys for the good advice. I have called Smith's in California, the firm that makes the clear penetrating epoxy sealer. They say that the CPES itself is a primer, so there is no need to further prime the surface, nor is there a need to scuff it up for tooth. Any paint will work, but the best is probably a two-part epoxy paint. I think that I may go get some Benjamin Moore enamel at Home Depot. Any objections?
post #7 of 32 Old 09-25-2014
Re: Paint for Cabin
Two part epoxy paints probably are the most durable, but for most of us in non-commercial applications, expensive overkill. Go to a paint store that carries bottom paint, that way everything else will look outright cheap.
post #8 of 32 Old 09-25-2014
Once known as Hartley18
Classic30's Avatar
Dock
Re: Paint for Cabin
You may not need a primer, but you still need an undercoat.
HS is correct, but the other thing to keep in mind is that timber hulls expand and contract, so ideally you need a top-coat that's flexible and won't crack away at the seams.
If you want to do it right, I'd suggest a two-pack undercoat over your CPES in the interior colour you choose, followed by two coats of a one-pack flexible mildew-resistant topcoat (like the Valspar Exterior that Tommays suggested) for the final coats. You could use a regular undercoat on the CPES just fine for years (and many people do) but keep in mind it may not adhere as well in some places if the surface get damp for long periods.
An extra tip: For the bilge area (below floorboards) and anywhere else relatively inaccessible like around the engine bay that's likely to get grime-covered, at the suggestion of a boatbuilder for some years now I've been using International Primocon - it's an antifouling primer, but is incredibly flexible and everything-resistant and does not require topcoating inside.
shisaisama likes this.
Classic30 is offline
The Following User Says Thank You to Classic30 For This Useful Post:
post #9 of 32 Old 09-25-2014 Thread Starter
Transplanted Yankee
Re: Paint for Cabin
Thanks, Classic30. You are probably right about an undercoat, for the reason of flexing timbers, that you give, and because the wood is now so dark that the white finish that I hope for will probably take two coats or white paint to achieve. Can you suggest a flexible two-pack undercoat? Manufacturer? Type of paint? Also, is Valspar the best enamel to use as a top coat? I have heard that Benjamin Moore makes some very good paint. Opinions?
post #10 of 32 Old 09-25-2014
Classic30's Avatar
Dock
Re: Paint for Cabin
Glad to help, shisaisama
Not being in your country I know nothing of Benjamin Moore but have heard good things about Valspar.
I doubt you'll find a flexible two-pack undercoat. You have two options:
1. Something like International Perfection Undercoat which is an ordinary two-pack epoxy that will adhere to your CPES. Smiths may also have an undercoat range you could use that is a close colour-match with your chosen topcoat.
2. If using Valspar Exterior (or similar latex or acrylic exterior enamel) use their recommended (one-pack) undercoat.
Which you choose comes down to money and time, really, with option 1 being the more durable of the two since there'll be a better bond between the CPES and the undercoat. Yes, you'll need at least one undercoat (maybe two if it's really dark), followed by two top-coats for the surface you describe.
Putting in new floors and a cabin sole. Also planning a new cabin layout. Advice? sully75 Gear & Maintenance 4 10-02-2013 01:30 PM
HVLP or Convential paint sprayer, & other paint equipment of choice patrscoe Gear & Maintenance 3 07-11-2011 11:46 AM
Prepping the cabin of my SC22 for painting? and paint Q? Perithead Gear & Maintenance 15 10-12-2008 03:16 PM
Should I put paint, carpet or both in the cabin ofmy 22' project boat? Perithead Gear & Maintenance 10 09-30-2008 02:27 PM
fastening to cabin fiberglass cabin interior marcusn Gear & Maintenance 3 09-06-2007 07:04 PM
